@Maddox Hi Jon, I was wondering if there’s a way to use your iTunes API and the Rest Switch to control both AirPlay devices and/or Playlists via a switch. Using your examples, shouldn’t these 2 work? Or is there another way to do this?
The restful switch won’t work, because it uses POST for it’s requests, without an option to change it. iTunes API uses PUT for commanding things like playlist switching and toggling airplay device state.
You could instead accomplish this with the command line switch:
switch:
- platform: command_line
switches:
bedroom_airplay:
friendly_name: Bedroom Airplay
command_on: "curl -X PUT http://192.168.1.10:8181/airplay_devices/63-22-fa-1f-f5-d4/on"
command_off: "curl -X PUT http://192.168.1.10:8181/airplay_devices/63-22-fa-1f-f5-d4/off"
outkast:
friendly_name: Outkast the 90s Playlist
command_on: "curl -X PUT http://192.168.1.10:8181/playlists/outkast-the-90s/play"
But, you do realize there’s a component inside HA for iTunes API right? When configured, it will expose your AirPlay devices as speakers with the ability to just turn them on and off. You can also send an event to the main iTunes accessory to set it’s playlist with media_player.play_media
Watch your URLs, you have and extra slash in the paths in your example that would cause issues. Also, you’re pointing at the GET URLs. Using the body with on/off and play wouldn’t do anything, the URLs need the full path as written in the docs.
Thanks Jon! I didn’t realize I could set a playlist that way. I’ll look into it tonight.
The reason I was looking into using switches is two-fold. First, I was wanting to create a playlist group that contains a page of playlists I can toggle on and off… Second, since 0.29 broke the iTunes Media Player (not your API, but the iTunes component is always offline now) I was thinking I could build this as an interim solution until it gets fixed as I just picked up an Amazon Echo and wanted to integrate some voice commands into my current airplay setup
Just to follow-up. It turns out it wasn’t broken, it’s that I had http://192.168.1.10 when I should just use the IP address ie 192.168.1.10
Also I managed to get the switches to also update their states and thought I’d post for others. This example supposes I have a an airplay device and a playlist called “The A List: Rock”
switches:
bathroom_airplay:
friendly_name: Bathroom Airplay
command_on: "curl -X PUT http://192.168.1.10:8181/airplay_devices/90-84-0d-f1-04-74/on"
command_off: "curl -X PUT http://192.168.1.10:8181/airplay_devices/90-84-0d-f1-04-74/off"
command_state: "curl -X GET http://192.168.1.10:8181/airplay_devices/90-84-0d-f1-04-74"
value_template: '{{ value_json["selected"] }}'
a_list_rock:
friendly_name: Rock
command_on: "curl -X PUT http://192.168.1.10:8181/playlists/the-a-list-rock/play"
command_off: "curl -X PUT http://192.168.1.10:8181/pause"
command_state: "curl -X GET http://192.168.1.10:8181/now_playing"
value_template: '{{ value_json["playlist"] == "The A List: Rock" }}'
Hi all, if anyone is interested, I have made some little buttons in lovelace using the custom button card that change the playlist to the one listed on the button. Maybe it will save some of you some time to do the same. There’s probably a cleaner way to do this with the rest_command, but this worked.
So first I defined the switches in my configuration.yaml pretty much as described above, except I made both toggle on and toggle off assigned to turn the playlist on. If I want a different playlist, I will just click that button, so the playlist button should always assign the chosen playlist regardless of state.
switch:
switches:
mix:
friendly_name: Mix
command_on: "curl -X PUT http://x.x.x.x:8181/playlists/a-45-star/play"
command_off: "curl -X PUT http://x.x.x.x:8181/playlists/a-45-star/play"
switches:
jazz:
friendly_name: Jazz
command_on: "curl -X PUT http://x.x.x.x:8181/playlists/best-jazz/play"
command_off: "curl -X PUT http://x.x.x.x:8181/playlists/best-jazz/play"
switches:
rock:
friendly_name: Rock
command_on: "curl -X PUT http://x.x.x.x:8181/playlists/best-rock/play"
command_off: "curl -X PUT http://x.x.x.x:8181/playlists/best-rock/play"
switches:
pop:
friendly_name: Pop
command_on: "curl -X PUT http://x.x.x.x:8181/playlists/best-pop/play"
command_off: "curl -X PUT http://x.x.x.x:8181/playlists/best-pop/play"
Then in ui-lovelace.yaml I defined the buttons as below (4 simple small text buttons in a row, but much more fancy ones are possible. I will probably make mine nicer someday)
- type: horizontal-stack
cards:
- type: "custom:button-card"
action: service
service:
domain: switch
action: toggle
entity_id: switch.mix
action: service
service:
domain: switch
action: toggle
entity_id: switch.jazz
action: service
service:
domain: switch
action: toggle
entity_id: switch.rock
action: service
service:
domain: switch
action: toggle
entity_id: switch.pop
I was playing around with this some more and it turns out that there’s actually nothing wrong with calling the service for play_media on media_player_itunes directly to change the playlist. No curl or shell commands needed. The following works fine:
And so you can create a button with the lovelace custom button card mentioned in my previous post as below (tested and working).
action: service
service:
domain: media_player
action: play_media
entity_id: "media_player.itunes"
media_content_id: "best-jazz"
media_content_type: "playlist"
Next I’m going to have it show which playlist is active using input_boolean and a script which you pass the playlist name in with a variable…
Then I’ll try an input_select for the subgenre of the selected genre… Will report back when I have something working.
I’m also trying to play from Apple generated playlists (e.g. “Favourites mix”) but can’t get it to work.
Also I can’t find a way to access playlists that contain spaces (standard fixes like adding a forward slash or %20 don’t work).
Does anyone have an idea?
You can see all the ones I defined in my config which I published to github… Some of them maybe had spaces but I generally avoid spaces exactly for reasons like this.
If you copy paste the name it says at http://YOUR_SERVER_IP:8181/playlists
it should work, at least it always has for me.
Can you help me?
So I added the shuffle function to my itunes.
How to get the status update? If I activate the shuffle function from itunes I would like it to activate also in HA.
My configuration is:
Wow well done, I moved on to other things and never came back to it, but it will be very nice to have ! Surprising that there’s an attribute for something there’s no service call for, I’m not sure I ever would have noticed that.
