I've just updated to v0.107.7, is the default GROUP gone?
Some panel like:
  • group.all_switches
  • group.all_devices
  • group.all_scripts
Display error, and I can not find the “default groups” in “state” anymore.
Been removed? or hiding somewhere?
There are apparently some things you could use in your groups yaml that changed. There are at least two topics addressing such things. Maybe you can take a look if you use any of those and change it to make the groups work again?
Yes, I’ve read this 2.
And at first I meet some problem about my manual set groups, after I remove the “control” param, them have back to normal.
But in my question, the “default group” is automatic there in elder version, not need any code.
I read the blog about v107 and found nothing about “deprecated”.
0.107: Multiple Lovelace Dashboards, adds helpers, new media player card - Home Assistant
I got it.
Default groups are missing since 0.104.0b0 · Issue #30687 · home-assistant/core
Entity Component to no longer generate automatic groups by balloob · Pull Request #23789 · home-assistant/core
I do love that feature, to list all the switches automaticlly, and I can found some one not use so often inside a entire button of “entity component”. sign.
