I've started getting the "Config flow could not be loaded" error and could use come help
I’ve been using the Adaptive Cover integration for many months now. Recently, I tried to edit the configuration, but when I click on the gear icon, I get this error:
“Config flow could not be loaded: 500 Internal Server Error — Server got itself in trouble.”
So far my troubleshooting hasn’t turned up anything useful. Other posts on the topic seem related to installing an integration, which is not where I’m having trouble. It’s installed and working – I just can’t edit it. While troubleshooting, I discovered two other integrations — Watchman and WundergroundPWS — misbehaving in the same way, so it doesn’t seem to be the Adaptive Cover integration itself that’s causing the problem.
Does anyone know what might be causing this or how I can fix it? For context, I’m running Home Assistant Container on a Synology NAS.
Same exact problem here. I’m running HAOS, and Adaptive Cover has been working fine, until this problem that’s not allowing to modify a cover’s existing configuration.
Not sure when it started because I just noticed when I tried to fine-tune the azymuth of a already-configured cover.
@cahuidob I’m not sure if the problem is with the integration or with my Home Assistant instance, but it doesn’t seem anybody has any suggestions for how to tackle this. I’ve given up on adaptive cover and switched to regular automations for our blinds. overall the integration has been more trouble than it’s worth – for me anyway.
I am suddenly having the same problem with my IKEA dirigera integration.
It worked flawlesly for a long time but now this.
I tried removing the Dirigera integration via HACS and in the integration itself. Reinstalling does not help. Rebooting is also no solution.
Help please?
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
Got exactly the same problem with the icsee-ptz camera integration. It’s installed but can’t go into setting to enable the additional entities
It took a while, but I found a solution to the problem. I’m posting it here in the hopes that it’s helpful to others:
The problem with this integration (and several others, as I learned) is that Home Assistant made a change that the author of the Adaptive Cover custom component integration hasn’t accounted for. The config_flow.py file of the integration needs to be edited to fix the problem.
Because my coding experience is getting pretty rusty, I asked Claude.ai to help me make the right changes so I’ll quote it directly here:
The error is clear. Here’s what’s happening and how to fix it:
The Error:
AttributeError: property 'config_entry' of 'OptionsFlowHandler' object has no setter
In a recent version of Home Assistant, OptionsFlowHandler (the base class) made config_entry a read-only property. The adaptive_cover integration’s OptionsFlowHandler.__init__ is still trying to assign to it directly (self.config_entry = config_entry), which now fails.
The Fix:
Open the file /config/custom_components/adaptive_cover/config_flow.py and find the OptionsFlowHandler.__init__ method around line 640. It looks like this:
def __init__(self, config_entry):
    self.config_entry = config_entry  # ← This line causes the error
Change it to store the entry under a different attribute name, and update any references to it within the class:
    self._config_entry = config_entry  # Use a private attribute instead
Then find every place in OptionsFlowHandler that uses self.config_entry and rename it to self._config_entry. (The base class’s self.config_entry property will still work correctly for HA internals — you just can’t assign to it.)
Alternatively, the cleanest modern HA pattern is to not pass config_entry to __init__ at all, since HA now injects it automatically via the config_entry property. You can remove the __init__ entirely and update async_get_options_flow to just:
@staticmethod
@callback
def async_get_options_flow(config_entry):
    return OptionsFlowHandler()
And in OptionsFlowHandler, replace self.config_entry with the inherited property (which is already set by HA automatically).
Quickest fix: In line 640, rename self.config_entryself._entry, and do a find-replace within the OptionsFlowHandler class to replace all self.config_entry with self._entry. This avoids touching the rest of the class logic.
I made the suggested edit in the config_flow.py file I found in config/custom_components/adaptive_cover, restarted Home Assistant and am now able to change the configuration as needed.
FWIW, I used Claude.ai to fix the config_flow errors in two other custom integrations (alarm.com and underground pws). In those cases, I didn’t even bother to edit the config_flow file myself. I uploaded it to Claude.ai and told it to make the changes itself. it worked. All I had to do it copy the resulting, edited file into the right director and restart HA.
I suspect, these edited files will get overwritten at some point when I do an update, but hopefully the authors of these integrations will fix them by then.
Thanks for your findings and fixes.
@basbrus was seen last in June 2025 here, so most probably it’s up to use to clone the repo and push the fixes.
There is a new implementation Adaptive Cover Pro, see over here Custom Component - Adaptive Cover - #113 by jrhubott
