I’ve created a very simple tile’ish interface for use on our cellphones, thanks to Zack’s nice video I finally took it up: https://www.youtube.com/watch?v=5y6rhwr5Y8c
I would like to keep the ‘advanced’ dashboard for the PC interface, and the more simple dashboard for the cellphones app.
But how do I do that?
In the app, open the side bar, go to “Configuration > Lovelace Dashboards”, select the dashboard you want to set for your device, and press ''Set as default on this device" (disclaimer: I’m using the iOS app, not sure if it works the same on Android).
Ahaaa, that works, great!
I tried changing it in the app settings, but that didn’t help
Now I just need kiosk mode activated, to get rid of the top bar, that must be possible as well
While that works it’s not really “automatic”.
I’ve suggested that there should be a way to assign a dashboard as default for mobile devices in the dashboard configuration menu. So it does not have to be assigned manually in each and every mobile device.
No real interest though:
Tru dat. It should be set as default, absolutely. You got my vote at least
But it’s a workaround, and good to know that it’s not me missing the point with the automagically.
