Jabber/XMPP server add on?
Anyone know if there’s one available for Home Assistant? Would be useful on the LAN here. Alternatively if anyone can recommend a server-less LAN client? Pidgin doesn’t support that I don’t think?
EDIT: Don’t worry, turns out Pidgin DOES support Bonjour. So I was able to implement server-less LAN chat with Pidgin/Bonjour.
how did you implement or set it up with ha and will it work with any client e.g. yaxim on android ?
I didn’t set anything up in the end as Pidgin supported Bonjour which is serverless
