I have a JA-82T interface cable hooked up to a JA-82K. I have connected the cable and (for all I know) identified it to be on /dev/hidraw0. The control panel shows up in Hass, but the status badge is “unknown”. I do not see any devices being reported in the config directory. I’ve enabled debugging for the component but have not spotted any actionable results, apart from a lot of unknown packets (which I believe mean the connection is working)
Search "jablotron" (191 hits in 1 file)
\\hassio\config\home-assistant.log (191 hits)
Line 89: 2020-03-22 10:45:50 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for jablotron which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
Line 90: 2020-03-22 10:45:50 INFO (MainThread) [homeassistant.loader] Loaded jablotron from custom_components.jablotron
Line 98: 2020-03-22 10:45:51 INFO (MainThread) [homeassistant.components.alarm_control_panel] Setting up alarm_control_panel.jablotron
Line 124: 2020-03-22 10:45:52 DEBUG (MainThread) [custom_components.jablotron.alarm_control_panel] Sending startup message
Line 125: 2020-03-22 10:45:52 DEBUG (MainThread) [custom_components.jablotron.alarm_control_panel] Successfully sent startup message
Line 141: 2020-03-22 10:45:52 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 185: 2020-03-22 10:45:53 DEBUG (MainThread) [custom_components.jablotron.alarm_control_panel] send_command_loop() enter
Line 193: 2020-03-22 10:45:53 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 201: 2020-03-22 10:45:53 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=alarm_control_panel.jablotron_alarm, old_state=None, new_state=<state alarm_control_panel.jablotron_alarm=unknown; code_format=number, changed_by=None, code_arm_required=True, friendly_name=Jablotron Alarm, supported_features=15 @ 2020-03-22T10:45:53.947459+01:00>>
Line 758: 2020-03-22 10:45:58 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 787: 2020-03-22 10:45:59 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 803: 2020-03-22 10:46:00 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 804: 2020-03-22 10:46:01 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 838: 2020-03-22 10:46:02 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 839: 2020-03-22 10:46:02 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01\xc6\x00\x00\x00\x00\x00'
Line 1120: 2020-03-22 10:46:07 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1121: 2020-03-22 10:46:08 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1122: 2020-03-22 10:46:08 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1154: 2020-03-22 10:46:09 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1155: 2020-03-22 10:46:09 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1156: 2020-03-22 10:46:10 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1193: 2020-03-22 10:46:13 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1870598416] Sending {'id': 11, 'type': 'result', 'success': True, 'result': [<state sun.sun=above_horizon; next_dawn=2020-03-23T05:03:42+00:00, next_dusk=2020-03-22T18:31:41+00:00, next_midnight=2020-03-22T23:48:26+00:00, next_noon=2020-03-22T11:48:52+00:00, next_rising=2020-03-23T05:37:26+00:00, next_setting=2020-03-22T17:57:59+00:00, elevation=33.01, azimuth=142.51, rising=True, friendly_name=Sun @ 2020-03-22T10:45:49.886158+01:00>, <state group.printer=unknown; entity_id=('sensor.samsung_clp_320_series_192_168_178_102_toner_black', 'sensor.samsung_clp_320_series_192_168_178_102_toner_cyan', 'sensor.samsung_clp_320_series_192_168_178_102_toner_magenta', 'sensor.samsung_clp_320_series_192_168_178_102_toner_yellow'), order=0, friendly_name=Samsung printer, icon=mdi:printer @ 2020-03-22T10:45:50.210117+01:00>, <state group.converter=unknown; entity_id=('sensor.total_yield', 'sensor.pv_power', 'senso...
Line 1198: 2020-03-22 10:46:13 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1870598416] Sending {'id': 12, 'type': 'result', 'success': True, 'result': {'latitude': 51.93666030300183, 'longitude': 4.495325982570649, 'elevation': 0, 'unit_system': {'length': 'km', 'mass': 'g', 'pressure': 'Pa', 'temperature': '°C', 'volume': 'L'}, 'location_name': 'W51', 'time_zone': 'Europe/Amsterdam', 'components': {'sensor.template', 'vacuum.xiaomi_miio', 'sensor.sma', 'cover.deconz', 'input_select', 'frontend', 'input_datetime', 'websocket_api', 'automation', 'group', 'alarm_control_panel.jablotron', 'light', 'sun', 'logger', 'input_text', 'light.switch', 'sensor.dsmr', 'light.deconz', 'sensor.buienradar', 'webhook', 'stream', 'map', 'emulated_hue', 'api', 'ios', 'light.tuya', 'device_automation', 'alarm_control_panel', 'updater', 'system_log', 'climate.deconz', 'device_tracker.mobile_app', 'binary_sensor.yeelight', 'media_player.cast', 'binary_sensor.deconz', 'persistent_notification',...
Line 1203: 2020-03-22 10:46:15 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1207: 2020-03-22 10:46:15 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1210: 2020-03-22 10:46:16 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1211: 2020-03-22 10:46:16 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1870598416] Sending {"id": 18, "type": "result", "success": true, "result": {"title": "W51", "views": [{"badges": [{"entity": "binary_sensor.updater"}, {"entity": "person.jacobijne"}, {"entity": "sensor.harmony_hub"}, {"entity": "sensor.plex_ntn_nas2"}, {"entity": "sensor.geocoded_location_3"}, {"entity": "sensor.geocoded_location_2"}, {"entity": "sun.sun"}], "cards": [{"entity": "media_player.woonkamer", "type": "media-control"}, {"entity": "media_player.home_mini", "type": "media-control"}, {"entities": ["binary_sensor.presence_3", "sensor.motion_sensor"], "show_header_toggle": true, "title": "Hal", "type": "entities"}, {"entities": ["sensor.daylight", "light.configuration_tool_2"], "show_header_toggle": true, "title": "Tuin", "type": "entities"}, {"entity": "media_player.mibox4", "type": "media-control"}, {"entities": ["sensor.br_humidity", "sensor.br_symbol", "sensor.br_temperature", "sensor.br...
Line 1213: 2020-03-22 10:46:16 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1236: 2020-03-22 10:46:17 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1258: 2020-03-22 10:46:17 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1339: 2020-03-22 10:46:17 DEBUG (SyncWorker_17) [homeassistant.util.json] JSON file not found: /config/custom_components/jablotron/.translations/alarm_control_panel.nl.json
Line 1417: 2020-03-22 10:46:18 DEBUG (SyncWorker_1) [homeassistant.util.json] JSON file not found: /config/custom_components/jablotron/.translations/alarm_control_panel.en.json
Line 1481: 2020-03-22 10:46:18 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
Line 1506: 2020-03-22 10:46:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1791843600] Sending {'id': 3, 'type': 'result', 'success': True, 'result': [<state sun.sun=above_horizon; next_dawn=2020-03-23T05:03:42+00:00, next_dusk=2020-03-22T18:31:41+00:00, next_midnight=2020-03-22T23:48:26+00:00, next_noon=2020-03-22T11:48:52+00:00, next_rising=2020-03-23T05:37:26+00:00, next_setting=2020-03-22T17:57:59+00:00, elevation=33.01, azimuth=142.51, rising=True, friendly_name=Sun @ 2020-03-22T10:45:49.886158+01:00>, <state group.printer=unknown; entity_id=('sensor.samsung_clp_320_series_192_168_178_102_toner_black', 'sensor.samsung_clp_320_series_192_168_178_102_toner_cyan', 'sensor.samsung_clp_320_series_192_168_178_102_toner_magenta', 'sensor.samsung_clp_320_series_192_168_178_102_toner_yellow'), order=0, friendly_name=Samsung printer, icon=mdi:printer @ 2020-03-22T10:45:50.210117+01:00>, <state group.converter=unknown; entity_id=('sensor.total_yield', 'sensor.pv_power', 'sensor...
Line 1513: 2020-03-22 10:46:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1791843600] Sending {'id': 6, 'type': 'result', 'success': True, 'result': {'latitude': 51.93666030300183, 'longitude': 4.495325982570649, 'elevation': 0, 'unit_system': {'length': 'km', 'mass': 'g', 'pressure': 'Pa', 'temperature': '°C', 'volume': 'L'}, 'location_name': 'W51', 'time_zone': 'Europe/Amsterdam', 'components': {'sensor.template', 'vacuum.xiaomi_miio', 'sensor.sma', 'cover.deconz', 'input_select', 'frontend', 'input_datetime', 'websocket_api', 'automation', 'group', 'alarm_control_panel.jablotron', 'light', 'sun', 'logger', 'input_text', 'light.switch', 'sensor.dsmr', 'light.deconz', 'sensor.buienradar', 'webhook', 'stream', 'map', 'emulated_hue', 'api', 'ios', 'light.tuya', 'device_automation', 'alarm_control_panel', 'updater', 'system_log', 'climate.deconz', 'device_tracker.mobile_app', 'binary_sensor.yeelight', 'media_player.cast', 'binary_sensor.deconz', 'persistent_notification', ...
Line 1528: 2020-03-22 10:46:21 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1791843600] Sending {"id": 16, "type": "result", "success": true, "result": {"title": "W51", "views": [{"badges": [{"entity": "binary_sensor.updater"}, {"entity": "person.jacobijne"}, {"entity": "sensor.harmony_hub"}, {"entity": "sensor.plex_ntn_nas2"}, {"entity": "sensor.geocoded_location_3"}, {"entity": "sensor.geocoded_location_2"}, {"entity": "sun.sun"}], "cards": [{"entity": "media_player.woonkamer", "type": "media-control"}, {"entity": "media_player.home_mini", "type": "media-control"}, {"entities": ["binary_sensor.presence_3", "sensor.motion_sensor"], "show_header_toggle": true, "title": "Hal", "type": "entities"}, {"entities": ["sensor.daylight", "light.configuration_tool_2"], "show_header_toggle": true, "title": "Tuin", "type": "entities"}, {"entity": "media_player.mibox4", "type": "media-control"}, {"entities": ["sensor.br_humidity", "sensor.br_symbol", "sensor.br_temperature", "sensor.br...
Line 1539: 2020-03-22 10:46:22 WARNING (ThreadPoolExecutor-0_0) [custom_components.jablotron.alarm_control_panel] Unknown status packet is b'\x82\x01`\x00\x00\x00\x00\x00'
The first thing I'd imagine I'd need to do is, establish whether the connection is configured correctly, ten work from there. Any pointers?
