Jacuzzi - Arctic Spas API
Hi I am Paul, and I’d love to be able to finally access my spas API key. I know your probably sick of people asking but if you could send me your contacts email address I’d really appreciate it. Thank you
They have added more functionality to the API now, I’ve added a couple of gauges for pH and chlorine levels now as well.
CL Low : orp below 400
CL Low-OK : orp in the range between 400 and 500
CL OK : orp in the range between 500 and 750
CL OK-High : orp in the range of 750 and 900
CL High : orp greater than 900
pH Low : below 680
pH Low-OK : 680 to 720
pH OK : 720 to 780
pH OK-High : 780 to 820
pH High : greater than 820
configuration.yaml
rest:
  - resource: https://api.myarcticspa.com/v2/spa/status
    headers:
      X-API-KEY: !secret arctic_spa_apikey
      Content-Type: application/json
    method: GET
    scan_interval: 60
      - name: "Spa PH level"
        value_template: "{{ value_json.ph }}"
      - name: "Spa PH status"
        value_template: "{{ value_json.ph_status }}"
      - name: "Spa chlorine level"
        value_template: "{{ value_json.orp }}"
      - name: "Spa chlorine status"
        value_template: "{{ value_json.orp_status }}"
Gauge cards
type: gauge
entity: sensor.spa_ph_level
name: Spa pH level
max: 8.8
min: 6.2
needle: true
segments:
    color: '#db4437'
    color: '#ffa600'
    color: '#43a047'
    color: '#ffa600'
    color: '#db4437'
type: gauge
entity: sensor.spa_chlorine_level
name: Spa chlorine level
max: 950
min: 350
needle: true
segments:
    color: '#db4437'
    color: '#ffa600'
    color: '#43a047'
    color: '#ffa600'
    color: '#db4437'
This is great, do you mind posting your entire config for the tub. I could would also appreciate the contact to request the API key access.
Thank you.
Sent the mail address by PM.
configuration.yaml
rest:
    headers:
    method: GET
    scan_interval: 60
      - name : "Spa Temperature"
        value_template: "{{ ((value_json.setpointF -32)|float(0) * 0.5556)|round(0)|int(0) }}"
        unit_of_measurement: "°C"
        device_class: temperature
      - name: "Spa Temperature Setpoint"
        unit_of_measurement: '°C'
    binary_sensor:
      - name: "Spa Status"
        value_template: "{{ value_json.connected }}"
        device_class: connectivity
      - name: "Spaboy Status"
        value_template: "{{ value_json.spaboy_connected }}"
      - name: "Spa Lights"
        value_template: "{{ value_json.lights|bool }}"
        device_class: power
      - name: "Spa Pump 1 Low"
        value_template: "{{ value_json.pump1 == 'low' }}"
        device_class: power
      - name: "Spa Pump 1"
        value_template: "{{ value_json.pump1 == 'high' }}"
        device_class: power
      - name: "Spa Pump 2"
        value_template: "{{ value_json.pump2 == 'high' }}"
        device_class: power
      - name: "Spa Pump 3"
        value_template: "{{ value_json.pump3 == 'high' }}"
        device_class: power
      - name: "Spa Pump 4"
        value_template: "{{ value_json.pump4 == 'high' }}"
        device_class: power
      - name: "Spa SDS"
        value_template: "{{ value_json.sds }}"
        device_class: power
rest_command:
  spa_lights_on:
    url: "https://api.myarcticspa.com/v2/spa/lights"
    method: PUT
    headers:
    payload: '{"state": "on"}'
  spa_lights_off:
    method: PUT
    headers:
    payload: '{"state": "off"}'
  spa_sds_on:
    url: "https://api.myarcticspa.com/v2/spa/sds"
    method: PUT
    headers:
  spa_sds_off:
    method: PUT
    headers:
  spa_pump_1_on:
    url: "https://api.myarcticspa.com/v2/spa/pumps/1"
    method: PUT
    headers:
  spa_pump_1_low:
    method: PUT
    headers:
    payload: '{"state": "low"}'
  spa_pump_1_off:
    method: PUT
    headers:
  spa_pump_2_on:
    url: "https://api.myarcticspa.com/v2/spa/pumps/2"
    method: PUT
    headers:
  spa_pump_2_off:
    method: PUT
    headers:
  spa_pump_3_on:
    url: "https://api.myarcticspa.com/v2/spa/pumps/3"
    method: PUT
    headers:
  spa_pump_3_off:
    method: PUT
    headers:
  spa_pump_4_on:
    url: "https://api.myarcticspa.com/v2/spa/pumps/4"
    method: PUT
    headers:
  spa_pump_4_off:
    method: PUT
    headers:
  spa_set_temperature:
    url: "https://api.myarcticspa.com/v2/spa/temperature"
    method: PUT
    headers:
    payload: '{"setpointF": {{ (states("input_number.spa_set_temperature")|float(0) * 1.8 + 32 )|round(0)|int(0) }} }'
switch:
    switches:
      spa_lights:
        friendly_name: Spa Lights
        value_template: "{{ states('binary_sensor.spa_lights') }}"
        turn_on:
          - service: rest_command.spa_lights_on
          - delay: 1
          - service: homeassistant.update_entity
            entity_id: binary_sensor.spa_lights # force the rest sensor to update rather than waiting for the scan interval
        turn_off:
          - service: rest_command.spa_lights_off
          - delay: 1
        icon_template: >
          {% if is_state('binary_sensor.spa_lights', 'on') %}
            mdi:lightbulb-on
          {% else %}
            mdi:lightbulb-off
          {% endif %}
      spa_pump_1:
        friendly_name: Spa Pump 1
        value_template: "{{ states('binary_sensor.spa_pump_1') }}"
        turn_on:
          - service: rest_command.spa_pump_1_on
          - delay: 1
            entity_id: binary_sensor.spa_pump_1 # force the rest sensor to update rather than waiting for the scan interval
        turn_off:
          - service: rest_command.spa_pump_1_off
          - delay: 1
        icon_template: >
          {% if is_state('binary_sensor.spa_pump_1', 'on') %}
            mdi:water
          {% else %}
            mdi:water-off
          {% endif %}
      spa_pump_1_low:
        friendly_name: Spa Pump 1 Low
        value_template: "{{ states('binary_sensor.spa_pump_1_low') }}"
        turn_on:
          - service: rest_command.spa_pump_1_low
          - delay: 1
            entity_id: binary_sensor.spa_pump_1_low # force the rest sensor to update rather than waiting for the scan interval
        turn_off:
          - delay: 2 # Larger delay because it goes to high before it turns off
        icon_template: >
            mdi:water
          {% else %}
            mdi:water-off
          {% endif %}
      spa_pump_2:
        friendly_name: Spa Pump 2
        value_template: "{{ states('binary_sensor.spa_pump_2') }}"
        turn_on:
          - service: rest_command.spa_pump_2_on
          - delay: 1
            entity_id: binary_sensor.spa_pump_2 # force the rest sensor to update rather than waiting for the scan interval
        turn_off:
          - service: rest_command.spa_pump_2_off
          - delay: 1
        icon_template: >
          {% if is_state('binary_sensor.spa_pump_2', 'on') %}
            mdi:water
          {% else %}
            mdi:water-off
          {% endif %}
      spa_pump_3:
        friendly_name: Spa Pump 3
        value_template: "{{ states('binary_sensor.spa_pump_3') }}"
        turn_on:
          - service: rest_command.spa_pump_3_on
          - delay: 1
            entity_id: binary_sensor.spa_pump_3 # force the rest sensor to update rather than waiting for the scan interval
        turn_off:
          - service: rest_command.spa_pump_3_off
          - delay: 1
        icon_template: >
          {% if is_state('binary_sensor.spa_pump_3', 'on') %}
            mdi:water
          {% else %}
            mdi:water-off
          {% endif %}
      spa_sds:
        friendly_name: Spa SDS
        value_template: "{{ states('binary_sensor.spa_sds') }}"
        turn_on:
          - service: rest_command.spa_sds_on
          - delay: 1
            entity_id: binary_sensor.spa_sds # force the rest sensor to update rather than waiting for the scan interval
        turn_off:
          - service: rest_command.spa_sds_off
          - delay: 1
        icon_template: >
          {% if is_state('binary_sensor.spa_sds', 'on') %}
            mdi:water
          {% else %}
            mdi:water-off
          {% endif %}
input_number:
    name: Spa Set Temperature
    min: 35
    max: 40
    step: 0.5
    icon: mdi:thermometer
from the dashboard:
  - theme: Backend-selected
    icon: mdi:bathtub
    title: Jacuzzi
    path: jacuzzi
    badges: []
    cards:
      - type: vertical-stack
        cards:
          - type: entities
            entities:
              - entity: switch.spa_lights
              - entity: sensor.spa_temperature
              - entity: sensor.spa_ph_status
              - entity: sensor.spa_chlorine_status
              - entity: input_number.spa_set_temperature
              - entity: switch.spa_pump_1
              - entity: switch.spa_pump_1_low
              - entity: switch.spa_pump_2
              - entity: switch.spa_pump_3
              - entity: switch.spa_sds
      - type: gauge
        name: Spa pH level
        max: 8.8
        min: 6.2
        needle: true
        segments:
            color: '#db4437'
            color: '#ffa600'
            color: '#43a047'
            color: '#ffa600'
            color: '#db4437'
      - type: gauge
        max: 950
        min: 350
        needle: true
        segments:
            color: '#db4437'
            color: '#ffa600'
            color: '#43a047'
            color: '#ffa600'
            color: '#db4437'
Great work, thx got it all working except for the PH and Clorine graphs.
What’s the code string to leave it in F and not convert it?
I got everything working except for setting temperature. It will not adjust.
I can give it a shot :slight_smile:
you need to modify the temperature sensor “Spa Temperature” to use the fahrenheit value from the API without modifying it, and change the unit_of_measurement to fahrenheit.
        value_template: "{{ value_json.setpointF }}"
        unit_of_measurement: "°F"
You have to modify payload for the spa_set_temperature so it don’t modify the value from the input_number.
    method: PUT
    headers:
    payload: '{"setpointF": {{ (states("input_number.spa_set_temperature") }} }'
You have to modify the input_number spa_set temperature min, max, step should be 1 and unit_of_mesaurement should be fahrenheit.
input_number:
    min: 95
    max: 104
    step: 1
you also need an automation to update the rest api when changing the value.
alias: Set Spa Temperature
description: ""
  - platform: state
    entity_id:
      - input_number.spa_set_temperature
condition: []
  - service: rest_command.spa_set_temperature
    data: {}
mode: single
Playing around with GUI now. I’m using picture element to control the pumps and light.
cards:
  - type: picture-elements
    elements:
      - type: state-icon
        style:
          top: 48%
          left: 48%
          transform: scale(2,2)
        tap_action:
          action: toggle
      - type: state-icon
        style:
          top: 67%
          left: 30%
        tap_action:
          action: toggle
      - type: state-icon
        style:
          top: 28%
          left: 30%
        tap_action:
          action: toggle
      - type: state-icon
        style:
          top: 48%
          left: 30%
        tap_action:
          action: toggle
      - type: state-icon
        style:
          top: 28%
          left: 60%
        tap_action:
          action: toggle
    image: /local/arcticspas/kodiak.png
  - type: horizontal-stack
    cards:
      - type: gauge
        name: Spa pH level
        max: 8.8
        min: 6.2
        needle: true
        segments:
            color: '#db4437'
            color: '#ffa600'
            color: '#43a047'
            color: '#ffa600'
            color: '#db4437'
      - type: gauge
        max: 950
        min: 350
        needle: true
        segments:
            color: '#db4437'
            color: '#ffa600'
            color: '#43a047'
            color: '#ffa600'
            color: '#db4437'
  - type: entities
    entities:
      - entity: weather.my_place
        secondary_info: none
This is awesome! If you can PM me the contact at Arctic for the API access that would be great! I have been looking at ways to integrate since i got my spa 3 months ago.
Wow !! Is it possible for you to sent me the whole setup and the contact at arctic so i can get the API access.
Do you have any plans to make a integration in HA
Hei :slight_smile:
Vært supert om du vil sende epost til han du fikk API key av!
Mvh Eirik
This is great stuff you guys are doing here ! If anyone can PM me the email address to request access to the API, I’d be thankful !
Many thanks for all contributors - got this working - here is an extended (more data from the API) and little modified REST part of configuration.yaml (for 2 pump model without SDS:):
rest:
    headers:
    method: GET
    scan_interval: 60
        device_class: water
        device_class: water
        device_class: water
        device_class: water
      - name: "Spa filtration status"
        value_template: "{{ value_json.filter_status }}"
        device_class: water
      - name: "Spa filtration duration"
        value_template: "{{ value_json.filtration_duration }}"
        device_class: water
      - name: "Spa filtration frequency"
        value_template: "{{ value_json.filtration_frequency }}"
        device_class: water
    binary_sensor:
      - name: "Spa Connection Status"
      - name: "Spaboy producing"
        value_template: "{{ value_json.spaboy_producing }}"
        device_class: power
        device_class: power
        device_class: power
        device_class: power
      - name: "Spa filter suspension"
        value_template: "{{ value_json.filter_suspension }}"
rest_command:
  spa_lights_on:
    method: PUT
    headers:
  spa_lights_off:
    method: PUT
    headers:
  spa_pump_1_on:
    method: PUT
    headers:
  spa_pump_1_low:
    method: PUT
    headers:
  spa_pump_1_off:
    method: PUT
    headers:
  spa_pump_2_on:
    method: PUT
    headers:
  spa_pump_2_off:
    method: PUT
    headers:
    method: PUT
    headers:
input_number:
    min: 33
    max: 40
    step: 0.5
And jhere a single card yaml for the same config - including more data
title: Arctic spa poreamme
cards:
  - type: entities
    entities:
      - entity: binary_sensor.spaboy_status
      - entity: binary_sensor.spaboy_producing
      - entity: sensor.spa_filtration_status
      - entity: sensor.spa_filtration_duration
      - entity: sensor.spa_filtration_frequency
  - type: gauge
    name: Spa pH level
    max: 8.8
    min: 6.2
    needle: true
    segments:
        color: '#db4437'
        color: '#ffa600'
        color: '#43a047'
        color: '#ffa600'
        color: '#db4437'
  - type: gauge
    max: 950
    min: 350
    needle: true
    segments:
        color: '#db4437'
        color: '#ffa600'
        color: '#43a047'
        color: '#ffa600'
        color: '#db4437'
I just contacted Arctic Spas support. They contacted my dealer, who confirmed what email address I registered under, and passed it along They will put a link to getting the API key in your account.
I figure this is better than all of us asking to be PM’ed. It took only 1 business day.
Hello all, is anyone figured out how to control blower?
Br J.
My API key does not seem to allow me access to my Spa Boy. Has anyone else found this please? It works fine in the official Arctic Spa app and via the web.
PM me with access contact please
For all those seeking the API key, you can contact Arctic Spa’s support through this page https://www.arcticspas.ca/en/contact/
They’ll reach to you within 24h by email to have the API access activated for your account. You’ll be then able to generate your own API key through the myarcticspa web portal !
I’m considering a purchase of an Arctic Spa and cloudless control is important to me. Is the api.myarcticspa.com DNS for your local spa, or does it require an Internet connection to talk to the cloud-based mothership?
