dagm
September 23, 2022, 10:14pm
1
Arctic Spas API
Hi, I’ve received early access to the Arctic Spas API.
I have minimal experience with both APIs and Home Assistant, but I’m learning as I go. And I think I’ve jumped to the deep end with this one, at least it feels like it.
I’ve managed to create sensors, not sure if it’s perfect, but now I’m trying to make a switch and it’s kind of difficult to figure out how to do it.
Any suggestions, tips and tricks or any kind of help would be greatly appricated.
What I’ve managed to do so far:
- platform: rest
resource: https://api.myarcticspa.com/v2/spa/status
headers:
X-API-KEY: !secret arctic_spa_apikey
Content-Type: application/json
method: GET
name: "Arctic Spa Status"
value_template: '{{ value_json.connected }}'
json_attributes:
- temperatureF
- setpointF
- lights
- pump1
- pump2
- pump3
- pump4
- pump5
scan_interval: 900
sensors:
arctic_spa_temperaturef:
friendly_name: "Temperature F"
value_template: "{{ state_attr('sensor.arctic_spa_status','temperatureF') }}"
sensors:
arctic_spa_setpointf:
friendly_name: "Temperature F setpoint"
value_template: "{{ state_attr('sensor.arctic_spa_status','setpointF') }}"
sensors:
arctic_spa_lights:
friendly_name: "Lights"
value_template: "{{ state_attr('sensor.arctic_spa_status','lights') }}"
sensors:
arctic_spa_pump1:
friendly_name: "Pump 1"
value_template: "{{ state_attr('sensor.arctic_spa_status','pump1') }}"
sensors:
arctic_spa_pump2:
friendly_name: "Pump 2"
value_template: "{{ state_attr('sensor.arctic_spa_status','pump2') }}"
sensors:
arctic_spa_pump3:
friendly_name: "Pump 3"
value_template: "{{ state_attr('sensor.arctic_spa_status','pump3') }}"
sensors:
arctic_spa_pump4:
friendly_name: "Pump 4"
value_template: "{{ state_attr('sensor.arctic_spa_status','pump4') }}"
sensors:
arctic_spa_pump5:
friendly_name: "Pump 5"
value_template: "{{ state_attr('sensor.arctic_spa_status','pump5') }}"
sensors:
arctic_spa_temperaturec:
friendly_name: "Temperature"
unit_of_measurement: '°C'
value_template: >-
{% set t = state_attr('sensor.arctic_spa_status','temperatureF') | float %}
{{((t)-32)*0.5556| round(2)}}
sensors:
arctic_spa_temperature_setpoint_c:
friendly_name: "Temperature setpoint"
value_template: >-
{% set t = state_attr('sensor.arctic_spa_status','setpointF') | float %}
What I’m struggeling with is to create a switch for the lights.
I’ve looked at rest switches with resource and state_resource, I’v looked at the rest_command, but I can’t figure out how to get it to work.
You can see the APIs here: https://api.myarcticspa.com/
I can get the light status from the template sensor above or this API call
And I can turn on and off the lights with this API call.
tom_l
September 24, 2022, 12:23am
2
Rather than using the rest sensor platform and a bunch of separate template sensors you can use the rest integration to get all your sensors from the one call to the resource and do the F → C conversion all in one go:
rest:
- resource: https://api.myarcticspa.com/v2/spa/status
headers:
method: GET
scan_interval: 60
- name : "Spa Temperature"
value_template: "{{ ( (value_json.temperatureF - 32) * 0.5556 )|round(1) }}"
unit_of_measurement: "°C"
device_class: temperature
- name: "Spa Temperature Setpoint"
value_template: "{{ ( (value_json.setpointF - 32) * 0.5556 )|round(1) }}"
binary_sensor:
- name: "Spa Status"
value_template: "{{ value_json.connected }}"
device_class: connectivity
- name: "Spa Lights"
value_template: "{{ value_json.lights|bool }}"
device_class: power
- name: "Spa Pump 1"
value_template: "{{ value_json.pump1|bool }}"
device_class: power
- name: "Spa Pump 2"
value_template: "{{ value_json.pump2|bool }}"
device_class: power
- name: "Spa Pump 3"
value_template: "{{ value_json.pump3|bool }}"
device_class: power
- name: "Spa Pump 4"
value_template: "{{ value_json.pump4|bool }}"
device_class: power
As for the switches you will need a rest command to turn each switch on, and another rest command to turn each switch off. You can then create a template switch from these commands and your sensors.
e.g. for the lights:
rest_command:
spa_lights_on:
url: "https://api.myarcticspa.com/v2/spa/lights"
headers:
payload: '{"state": "on"}'
spa_ligfhts_off:
headers:
payload: '{"state": "off"}'
Test these rest_commands in Developer Tools → Services. If they work then you can proceed to creating your switch:
switch:
switches:
spa_lights:
friendly_name: Spa Lights
value_template: "{{ states('binary_sensor.spa_lights') }}"
turn_on:
- service: rest_command.spa_lights_on
- delay: 1
- service: homeassistant.update_entity
entity_id: binary_sensor.spa_lights # force the rest sensor to update rather than waiting for the scan interval
turn_off:
- service: rest_command.spa_lights_off
- delay: 1
icon_template: >
{% if is_state('binary_sensor.spa_lights', 'on') %}
mdi:lightbulb-on
{% else %}
mdi:lightbulb-off
{% endif %}
spa_pump_1:
friendly_name: Spa Pump 1
... repeat as above.
tom_l
September 24, 2022, 1:06am
3
For setting the temperature set point create an input_number (in °C, we’ll convert it before sending):
spa_set_temperature:
name: Spa Set Temperature
min: 25
max: 35 # or whatever the min and max are
step: 0.1
icon: mdi:thermometer
Then create a rest command
rest_command:
url: "https://api.myarcticspa.com/v2/spa/temperature"
headers:
payload: '{"setpointF": (states("input_number.spa_set_temperature")|float(0) * 1.8) - 32 )|round(0)|int(0) }'
You will then need an automation to get (if changed outside HA) and set (if the input number is changed) the temperature:
- alias: 'Set Spa Temperature'
- platform: state
entity_id: input_number.spa_set_temperature
to:
condition:
- condition: template
value_template: "{{ trigger.to_state.state not in ['unknown', 'unavailable'] }}"
value_template: "{{ states('sensor.spa_temperature_setpoint')|float(30) != states('input_number.spa_set_temperature')|float(30) }}"
- service: rest_command.spa_set_temperature
- alias: 'Get Spa Temperature'
- platform: state
entity_id: sensor.spa_temperature_setpoint
to:
condition:
- service: input_number.set_value
value: "{{ states('sensor.spa_temperature_setpoint')|float(30) }}"
Be very careful with the precision here. Epsilon errors may cause these two automations to loop forever. However I think by rounding to 1 decimal place in your Spa Temperature Setpoint sensor we should be ok. If it does loop forever we’ll have to use the format function as well as the round filter.
Alternatively you can do everything in °F and integers rather than °C floating point numbers.
dagm
September 24, 2022, 8:26am
4
Thanks! I would never have figured out this on my own. I’ll try and find some time to play around with it this weekend.
dagm
September 24, 2022, 7:39pm
5
I got the light switch to work and I’m working on the pump switches now. I got one issue, and that is the ‘on’ state of the pump return ‘high’ when the pump is running. I guess I need to convert ‘high’ to a boolean.
I was hoping this would work, but it’s not, any suggestions?
binary_sensor:
value_template: "{% if is_state('value_json.pump1', 'high') %}true{% else %}false{% endif %}"
device_class: power
EDIT:
I figured it out. This will return true or false.
binary_sensor:
value_template: "{{ value_json.pump1 == 'high' }}"
tom_l
September 24, 2022, 11:00pm
6
Doe it have more than two states?
e.g.
high
med
low
off
dagm
September 25, 2022, 7:02am
7
Pump1 has three states. off,low and high. The other pumps only have high and off.
tom_l
September 25, 2022, 7:22am
8
It should be a sensor then. Not a binary_sensor.
For the switch for it you have a couple of options.
use two switches, one for high, one for low, or…
Use an input_select with the three options off, low, high and then automate which rest command is sent based on the state of this input select.
dagm
September 25, 2022, 8:05am
9
Thanks, I’ll see how the input_select works and decide. The low state is mostly used by the tub to heat the water.
I might need it when they expand the api with energy data and PH level.
dagm
September 25, 2022, 1:48pm
10
I tried to change the payload string,but when I paste it in the configuration it looks like it’s not properly formated.
payload: '{"setpointF": "{{ (states('input_number.spa_set_temperature')|float(0)* 1.8 +32|round(0))|int(0)}}" }'
When I paste it in it looks like this:
I think I got most of the configuration now except the set temperature.
configuration.yaml
rest:
headers:
method: GET
scan_interval: 60
value_template: "{{ ((value_json.setpointF -32)|float(0) * 0.5556)|round(0)|int(0) }}"
binary_sensor:
device_class: power
- name: "Spa Pump 1 Low"
value_template: "{{ value_json.pump1 == 'low' }}"
device_class: power
device_class: power
value_template: "{{ value_json.pump2 == 'high' }}"
device_class: power
value_template: "{{ value_json.pump3 == 'high' }}"
device_class: power
value_template: "{{ value_json.pump4 == 'high' }}"
device_class: power
rest_command:
spa_lights_on:
method: PUT
headers:
spa_lights_off:
method: PUT
headers:
spa_pump_1_on:
url: "https://api.myarcticspa.com/v2/spa/pumps/1"
method: PUT
headers:
spa_pump_1_low:
method: PUT
headers:
payload: '{"state": "low"}'
spa_pump_1_off:
method: PUT
headers:
spa_pump_2_on:
url: "https://api.myarcticspa.com/v2/spa/pumps/2"
method: PUT
headers:
spa_pump_2_off:
method: PUT
headers:
spa_pump_3_on:
url: "https://api.myarcticspa.com/v2/spa/pumps/3"
method: PUT
headers:
spa_pump_3_off:
method: PUT
headers:
spa_pump_4_on:
url: "https://api.myarcticspa.com/v2/spa/pumps/4"
method: PUT
headers:
spa_pump_4_off:
method: PUT
headers:
method: PUT
headers:
payload: '{"setpointF": }'
switch:
switches:
spa_lights:
turn_on:
- delay: 1
turn_off:
- delay: 1
icon_template: >
mdi:lightbulb-on
{% else %}
mdi:lightbulb-off
{% endif %}
spa_pump_1:
value_template: "{{ states('binary_sensor.spa_pump_1') }}"
turn_on:
- service: rest_command.spa_pump_1_on
- delay: 1
entity_id: binary_sensor.spa_pump_1 # force the rest sensor to update rather than waiting for the scan interval
turn_off:
- service: rest_command.spa_pump_1_off
- delay: 1
icon_template: >
{% if is_state('binary_sensor.spa_pump_1', 'on') %}
mdi:water
{% else %}
mdi:water-off
{% endif %}
spa_pump_1_low:
friendly_name: Spa Pump 1 Low
value_template: "{{ states('binary_sensor.spa_pump_1_low') }}"
turn_on:
- service: rest_command.spa_pump_1_low
- delay: 1
entity_id: binary_sensor.spa_pump_1_low # force the rest sensor to update rather than waiting for the scan interval
turn_off:
- delay: 2 # Larger delay because it goes to high before it turns off
icon_template: >
mdi:water
{% else %}
mdi:water-off
{% endif %}
spa_pump_2:
friendly_name: Spa Pump 2
value_template: "{{ states('binary_sensor.spa_pump_2') }}"
turn_on:
- service: rest_command.spa_pump_2_on
- delay: 1
entity_id: binary_sensor.spa_pump_2 # force the rest sensor to update rather than waiting for the scan interval
turn_off:
- service: rest_command.spa_pump_2_off
- delay: 1
icon_template: >
{% if is_state('binary_sensor.spa_pump_2', 'on') %}
mdi:water
{% else %}
mdi:water-off
{% endif %}
spa_pump_3:
friendly_name: Spa Pump 3
value_template: "{{ states('binary_sensor.spa_pump_3') }}"
turn_on:
- service: rest_command.spa_pump_3_on
- delay: 1
entity_id: binary_sensor.spa_pump_3 # force the rest sensor to update rather than waiting for the scan interval
turn_off:
- service: rest_command.spa_pump_3_off
- delay: 1
icon_template: >
{% if is_state('binary_sensor.spa_pump_3', 'on') %}
mdi:water
{% else %}
mdi:water-off
{% endif %}
input_number:
min: 15
max: 40
step: 0.5
tom_l
September 26, 2022, 12:27am
11
Look at my example again. Yours has the parentheses in the wrong place and so you are only rounding the number 32.
dagm
September 26, 2022, 6:26am
12
I tried to use it but nothing is happening.I tried to modify your example from
to
payload: '{"setpointF": ((states("input_number.spa_set_temperature")|float(0) * 1.8) - 32 )|round(0)|int(0) }'
It seemed like it was missing a ( infront of states. Still does not work.
This is how it looks like when I paste it in the Template section under Dev Tools
tom_l
September 26, 2022, 6:36am
13
payload: '{"setpointF": {{ (states("input_number.spa_set_temperature")|float(0) * 1.8 - 32 )|round(0)|int(0) }} }'
dagm
September 26, 2022, 6:54am
14
YES! it works! I just had to modified -32 to +32 to get the calculation right. Thank you for bearing with me!
method: PUT
headers:
payload: '{"setpointF": {{ (states("input_number.spa_set_temperature")|float(0) * 1.8 + 32 )|round(0)|int(0) }} }'
mariagim
(Mariagim)
October 1, 2022, 12:35am
15
Hey dagm,
I’m trying to get an apikey. How do I get it?
-g
dagm
October 1, 2022, 9:21am
16
Hi, it’s in early access at the moment so they will probably need to give you access.
Try this page and see if you can create one:
API Key Management (myarcticspa.com)
mariagim
(Mariagim)
October 1, 2022, 12:27pm
17
I got " Error Page! Page doesn’t exist or some other error occured. Go to our home page or go back to [previous page](javascript:history.back())"
message.
Do I call and request one?
dagm
October 1, 2022, 3:24pm
18
I’ll send you the email address to the guy that gave me access. I don’t want to post it online so I’ll send it by PM.
shiva979
(Shiva979)
October 9, 2022, 3:04pm
19
Keen also - could you PM me the email please?
pauly802
(Paul Lenoce Jr)
October 9, 2022, 11:53pm
20
Did you ever find out how to get your API key by chance?
