I moved to Home Assistant from Homeseer recently. There were some things that the Homeseer version of the iAqualink integration had that the Home Assistant integration doesn’t seem to have, or at least it doesn’t work in Home Assistant. One of the biggest missing items is the ability to grab the Salt PPM from iAqualink so that I can set a reminder to add salt to my pool when it reaches a preset level.
The current integration has a Pool Salinity sensor as well as a Spa Salinity sensor, but neither one of these seem to return a value. It’s simply zero. I’d be more than happy to work with the developer to help find the values as I do have a working iAqualink system complete with the Aquapure Chorine generator.
