@LIGISTX @SteveOnorato
I followed this exactly and I cannot get the color to be selected no matter what I do. Any ideas? If I remove the color portion the light will turn on and off. I have also tried different colors and I dont have any luck that way either…
Logger: homeassistant.components.websocket_api.http.connection
Source: components/iaqualink/utils.py:14
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 5:22:54 PM (1 occurrences)
Last logged: 5:22:54 PM
[140566835602192] 'SKY_BLUE'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 192, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1636, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1673, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 282, in service_handler
await script_entity.async_turn_on(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 386, in async_turn_on
await coro
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 412, in _async_run
return await self.script.async_run(script_vars, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1243, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 349, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 367, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 570, in _async_call_service_step
await service_task
task.result()
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 671, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 949, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 708, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 504, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/iaqualink/__init__.py", line 202, in wrapper
await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/iaqualink/light.py", line 59, in async_turn_on
await await_or_reraise(self.dev.set_effect_by_name(effect_name))
File "/usr/src/homeassistant/homeassistant/components/iaqualink/utils.py", line 14, in await_or_reraise
await awaitable
File "/usr/local/lib/python3.9/site-packages/iaqualink/device.py", line 374, in set_effect_by_name
effect_num = self.supported_light_effects[effect_name]
KeyError: 'SKY_BLUE'
