could you please plan to create the Jarvis assistant add on ?
Sincerely thanks.
What exactly is it you are hoping for here?
~Cheers
I saw you launched the Hass.io with some add-ons.
And when I read the last voice control, I though you may simply add the so great Jarvis (command control) as an add-on for Hass.io.
Jarvis is a light consumer of resources.
Then the author is already working for its great home voice control (with Jarvis) and then you just need to make a “bridge” with HA and let him to upgrade its voice control command.
It will simplify you Home Assistant maintenance (Jarvis already has a web interface) and use the power of its work to join it on HA.
Best regards
