I have 7 of these in my home and all of them are now running Firmware 5.25 (thank you HA team for updates).
I have discovered something (to me) frustrating. This parameter is wrong: [9-112-0-3] LED Indicator
According to everything I can find and from the ZWave JS site - if this is set to “0” - the light is ON when the Device is OFF (which is default and what I want)…so that you can find as needed in the dark.
Everyone of mine, when I set them to “0” - the light will be OFF when the device is OFF (which would indicate parameter 3 is set to a ‘1’. In order to get the LED to be ON when the switch is OFF - I have to set the parameter to “1” - not “0” as the site would indicate.
I have also tried the (press 10 times feature) and it does change the LED - but when you interview the node - Parameter 3 = “1” not “0”.
Is there some way to fix this?
