Jc8012p4a1-guition-esp32-p4_esp32-c6
Hi all. I thought I would start a new topic for the ESP32-P4 + ESP32-C6 device by Guition with a 10.1" display that can be found for rather cheap on AliExpress:
https://www.aliexpress.com/item/1005009147577522.html?spm=a2g0o.detail.1000023.1.2fa43hUz3hUzla
Through a number of posts on GitHub and here I been able to get some of the basic functionality working. However there are lots of things that don’t. My main source of information was from Willumpie82 on Github.
  • Display: Uses the MIPI_DSI driver. Seems to not support HW rotation, and default is in portrait mode.
  • Touch: Uses the GSL3680 chip and does require using the specific code/drivers found in Willumpie82’s YAML file otherwise it will fail.
  • Wifi/BT: Works out of the box.
  • Camera: Supposedly uses an OV02C10 sensor, and the P4 uses a CSI protocol. Have not found a method to interface them yet.
  • Speaker: Board has an ES8311 codec for DAC. Tried code using this but no success getting any output.
  • Microphone: Needs to have an ADC defined, and from the documentation it shows a reference to an ES7210 ADC, but that fails to be detected. The ES8311 documentation shows that it also has ADC functionality, but there are no drivers in place for that.
Perhaps we can use this topic to track what works and not, as well as tips/tricks we have discovered.
This is my YAML code thus far:
# Home Assistant/System Setup
captive_portal:
http_request:
web_server:
  port: 80
esphome:
  comment: ${comment}
  friendly_name: ${friendly_name}
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxx"
  on_client_connected:
    - if:
        condition:
          lambda: 'return (0 == client_info.find("Home Assistant "));'
        then:
          - lvgl.label.update:
              text_color: ${color_white}
              text: ${mdi_wifi}
          - logger.log: "Wifi found"
  on_client_disconnected:
    - if:
        condition:
        then:
              text_color: ${color_warning}
              text: ${mdi_wifi_off}
          - logger.log: "No wifi"
# Example configuration entry
button:
  - platform: restart
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxxxxxx"
wifi:
  ssid: "xxxxxx"
  password: "xxxxxxx"
  output_power: "8.5db"
esp32:
  board: esp32-p4-evboard
  cpu_frequency: 400MHz
  flash_size: 16MB
  framework:
    type: esp-idf
    advanced:
      enable_idf_experimental_features: yes
logger:
  hardware_uart: USB_SERIAL_JTAG
  level: DEBUG
  logs:
    lvgl: DEBUG
    display: DEBUG
    app: DEBUG
esp_ldo:
  - channel: 3
    voltage: 2.5V
esp32_hosted:
  variant: ESP32C6
  reset_pin: 54
  cmd_pin: 19
  clk_pin: 18
  d0_pin: 14
  d1_pin: 15
  d2_pin: 16
  d3_pin: 17
  active_high: true
psram:
  speed: 200MHz
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
globals:
  - id: counter
    type: int
    restore_value: no
    initial_value: '10'
  - id: door_locked
    type: bool
    restore_value: no
    initial_value: "false"
# Internal Assignments/Preparation
substitutions:
  device_name: "p4tablet"
  friendly_name: "P4 tablet"
  comment: "esp32-P4"
  # Material Design Icons
  mdi_wifi: "\U000F05A9"
  mdi_wifi_off: "\U000F05AA"
  mdi_power: "\U000F0425"
  mdi_thermometer: "\U000F050F"
  mdi_lock_unlocked: "\U000F033F"
  mdi_lock_locked: "\U000F033E"
  color_warning: "0xd2691e"
  color_white: "0xFFFFFF"
external_components:
  - source: github://willumpie82/esphome@dev
    components: [mipi_dsi]
  - source: github://kvj/esphome@jd9365_gsl3680
    refresh: 0s
    components: [gsl3680]
  - source: github://esphome/[email protected]
    components: [i2c]
# Interval checks
interval:
  - interval: 10s
    then:
# Periodically checking on light switch status to update buttons
      - lvgl.obj.update:
          bg_image_src: door_snapshot
      - if:
          condition:
            lambda: 'return id(front_door_lock_sensor).state == "locked";'
          then:
                text_color: "0xffffff"
                text: ${mdi_lock_locked}
            - logger.log: "Door is locked"
          else:
                text_color: "0xFF4500"
                text: ${mdi_lock_unlocked}
            - logger.log: "Door is unlocked"
      - if:
          condition:
            switch.is_on: dining_light_switch
          then:
            - lvgl.button.update:
                bg_color: "0xff4500"
            - logger.log: "Dining Light is on"
          else:
                bg_color: "0x222222"
            - logger.log: "Dining Light is off"
      - if:
          condition:
            switch.is_on: living_light_switch
          then:
            - logger.log: "Living Room Light is on"
          else:
            - logger.log: "Living Room Light is off"
      - if:
          condition:
            switch.is_on: kitchen_light_switch
          then:
            - logger.log: "Kitchen Light is on"
          else:
            - logger.log: "Kitchen Light is off"
#  Periodic updates to temperatures and humidity
      - homeassistant.service:
          service: homeassistant.update_entity
            entity_id: sensor.hallway_temperature
            entity_id: sensor.home_realfeel_temperature
            entity_id: sensor.hallway_humidity
            entity_id: lock.front_door
            entity_id: switch.dining_room_light
      # Update the label text manually
      - lambda: |-
          if (id(ha_temperature_sensor).has_state()) {
            char temp_str[10]; // Buffer to store formatted string (e.g., "23.50°C")
            float temp = id(ha_temperature_sensor).state;
            snprintf(temp_str, sizeof(temp_str), "%.2f°C", temp); // Formats to 2 decimals
            lv_label_set_text(id(temp_value_label), temp_str);
          } else {
            lv_label_set_text(id(temp_value_label), "--- °C");
          if (id(ha_outsidetemperature_sensor).has_state()) {
            float temp = id(ha_outsidetemperature_sensor).state;
            lv_label_set_text(id(outtemp_value_label), temp_str);
          } else {
            lv_label_set_text(id(outtemp_value_label), "--- °C");
# Sensor Definitions
# --- Define Sensors to fetch data from Home Assistant ---
  - platform: homeassistant
    internal: true #
    unit_of_measurement: "°C"
    internal: true
    internal: true
    unit_of_measurement: "%"
  - platform: uptime
    entity_category: "diagnostic"
    update_interval: 60s
  - platform: wifi_signal
    icon: mdi:wifi-arrow-left-right
    entity_id: sensor.front_door_battery
    icon: mdi:mdi_lock_locked
text_sensor:
  - platform: wifi_info
    ip_address:
      icon: mdi:ip-network
    ssid:
      icon: mdi:wifi-check
    mac_address:
output:
  # Backlight LED
  - platform: ledc
    pin: GPIO23
    frequency: 100Hz
    min_power: 0.03
    zero_means_zero: true
light:
  - platform: monochromatic
    output: GPIO23
    restore_mode: RESTORE_DEFAULT_ON
switch:
    internal: true
    entity_id: switch.entryway_light
    internal: true
    entity_id: switch.hallway_light
    internal: true
    entity_id: switch.kitchen_light
    internal: true
    entity_id: switch.living_room_lamp
    internal: true
    entity_id: switch.stair_light
    internal: true
lock:
    name: "Front Door Lock"
    lock_action:
    - logger.log: "Door Locked"
    unlock_action:
    - logger.log: "Door Unlocked"
# LVGL Display
display:
  - platform: mipi_dsi
    model: JC8012P4A1
    update_interval: 1s
    reset_pin: GPIO27
    rotation: 180
    auto_clear_enabled: false
    color_order: RGB
    dimensions:
      width: 800
      height: 1280
i2c:
  - id: i2c_bus
    sda: GPIO7
    scl: GPIO8
    scan: true
    frequency: 400kHz
i2c_device:
  - id: i2cdev1
    address: 0x18
  - id: i2cdev2
    address: 0x32
  - id: i2cdev3
    address: 0x36
  - id: i2cdev4
    address: 0x40
touchscreen:
  - platform: gsl3680
    reset_pin: GPIO22
    interrupt_pin: GPIO21
    transform:
      swap_xy: false
      mirror_x: true
      mirror_y: true
    on_touch:
        - light.turn_on: backlight
        - lvgl.widget.redraw:
font:
  - file: "fonts/arial.ttf"
    extras:
    - file: "fonts/materialdesignicons-webfont.ttf"
      glyphs:
        - ${mdi_wifi}
        - ${mdi_wifi_off}
        - ${mdi_power}
        - ${mdi_thermometer}
        - ${mdi_lock_locked}
        - ${mdi_lock_unlocked}
    extras:
      glyphs:
        - ${mdi_wifi}
        - ${mdi_wifi_off}
        - ${mdi_power}
    extras:
      glyphs:
        - ${mdi_wifi}
        - ${mdi_wifi_off}
        - ${mdi_power}
    extras:
      glyphs:
        - ${mdi_wifi}
        - ${mdi_wifi_off}
        - ${mdi_power}
    extras:
      glyphs:
        - ${mdi_wifi}
        - ${mdi_wifi_off}
        - ${mdi_power}
    extras:
      glyphs:
        - ${mdi_wifi}
        - ${mdi_wifi_off}
        - ${mdi_power}
image:
  defaults:
    type: rgb565
    # zzzz
  images:
    - file: https://esphome.io/_images/logo.png
      resize: 200x162
online_image:
  - url: http://192.168.0.7:8123/local/snapshot.jpg
    type: RGB565
    format: JPEG
    resize: 340x200
    update_interval: 30s
    byte_order: LITTLE_ENDIAN
time:
  - platform: sntp
    timezone: America/Toronto
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
    on_time_sync:
      - script.execute: time_update
    on_time:
      - minutes: '*'
        seconds: 0
        then:
script:
  - id: time_update
    then:
          text: !lambda |-
            static char time_buf[17];
            auto now = id(sntp_time).now();
            snprintf(time_buf, sizeof(time_buf), "%02d:%02d", now.hour, now.minute);
            return time_buf;
lvgl:
  buffer_size: 100%
  byte_order: little_endian
  touchscreens:
    - touchscreen_id: touchscreen_
  on_idle:
    - timeout: 10s
      then:
        - logger.log: idle timeout
        - light.turn_off:
            transition_length: 5s
  color_depth: 16
  bg_color: 0x000000
  border_width: 0
  style_definitions:
    - id: header_footer
      bg_color: 0x2F8CD8
      bg_grad_color: 0x005782
      bg_grad_dir: VER
      bg_opa: COVER
      border_opa: TRANSP
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      border_color: 0x0077b3
      text_color: 0xFFFFFF
      width: 100%
      height: 50
    - id: advanced_btn_style
      text_color: 0xD5D5D5
      bg_color: 0x222222
      bg_opa: COVER
      radius: 20
      outline_width: 0
      border_width: 0
      #border_opa:
      pad_all: 0
    # --- Base Styles ---
    - id: base_panel_style
      bg_color: 0x000000
      border_width: 0
      radius: 0
      pad_all: 0
    # --- Section Styles ---
    - id: section_panel_style
      bg_color: 0x111111
      border_width: 1
      border_color: 0x444444
      radius: 10
      pad_all: 0
    # --- Label Styles ---
    - id: title_label_style
      text_font: font_medium
      text_color: 0xCCCCCC
      align: CENTER
      bg_opa: TRANSP
    - id: sensor_value_style
      text_font: font_very_small
      align: CENTER
      bg_opa: TRANSP
    - id: sensor_value_style2
      text_color: 0x89FF88
      align: CENTER
      bg_opa: TRANSP
    - id: button_label_style
      align: CENTER
      bg_opa: TRANSP
    - id: button_label_style2
      text_font: font_small
      align: CENTER
      bg_opa: TRANSP
    # --- Button Style ---
    - id: button_style
      bg_color: 0x00ABCD #0x0000FF
      radius: 15
      border_width: 1
      border_color: 0xCCCCCC
      pad_all: 10
  top_layer:
    widgets:
      - buttonmatrix:
          align: bottom_mid
          styles: header_footer
          pad_all: 0
          outline_width: 0
          items:
          rows:
            - buttons:
              - id: page_prev
                text: "\uF053"
                on_press:
                  then:
                    lvgl.page.previous:
              - id: page_home
                text: "\uF015"
                on_press:
                  then:
                    lvgl.page.show: main_page
              - id: page_next
                text: "\uF054"
                on_press:
                  then:
                    lvgl.page.next:
      - label:
          hidden: false
          align: top_right
          x: -75
          y: 0
          text_align: right
      - label:
          styles: sensor_value_style
          align: TOP_LEFT
          x: 35
      - label:
          align: TOP_LEFT
          x: 90
      - label:
          text: "--:--"
          styles: sensor_value_style2
          align: TOP_RIGHT
          x: -35
  pages:
    - id: main_page
      widgets:
        # --- Main Container ---
        - obj:
            styles: base_panel_style
            width: 800
            height: 480
            widgets:
              # === Left Panel (Sensors) ===
              - obj:
                  width: 360
                  height: 470
                  align: TOP_LEFT
                  x: 35
                  y: 15
                  widgets:
                    # --- Temperature Section ---
                    - obj:
                        styles: section_panel_style
                        width: 360
                        height: 225
                        align: TOP_MID
                        widgets:
                          - label:
                              hidden: false
                              align: CENTER
                              x: 0
                              y: 0
                              text_align: CENTER
                              text_font: font_very_large
                          - label:
                              styles: title_label_style
                              align: TOP_MID
                              y: 5
                              text: "Front Door Lock"
                    # --- Humidity Section ---
                    - obj:
                        width: 360
                        height: 205
                        y: -20
                        align: BOTTOM_MID
                        widgets:
                          - label:
                              align: TOP_MID
                              text: "Last Door Event"
              # === Right Panel (Buttons & Counter) ===
              - obj:
                  width: 360
                  height: 470
                  align: TOP_RIGHT
                  x: -35
                  y: 15
                  bg_color: 0x222222
                  widgets:
                    # --- Toggle Buttons Section ---
                    - obj:
                        width: 360
                        height: 200
                        align: TOP_MID
                        bg_color: 0x222222
                        layout: # Layout is a dictionary
                          type: flex
                          flex_flow: COLUMN
                          flex_align_main: SPACE_EVENLY
                          flex_align_cross: CENTER
                          flex_align_track: CENTER
                          pad_column: 10
                        widgets:
                          # --- Button 1: Test Light ---
                          - button:
                              styles: advanced_btn_style #button_style
                              width: 250
                              height: 50
                              on_click:
                                then:
                                  - switch.toggle: dining_light_switch
                                  - logger.log: "Toggled 1 via HA service"
                                  - if:
                                      condition:
                                        switch.is_off: dining_light_switch
                                      then:
                                      else:
                              widgets:
                                - label:
                                    styles: button_label_style
                                    text: "Dining Room"
                          # --- Button 2: Placeholder ---
                          - button:
                              width: 250
                              height: 50
                              on_click:
                                then:
                                  - switch.toggle: kitchen_light_switch
                                  - logger.log: "Toggled 2 via HA service"
                                  - if:
                                      condition:
                                        switch.is_off: kitchen_light_switch
                                      then:
                                      else:
                              widgets:
                                - label:
                                    text: "Kitchen"
                          # --- Button 3: Placeholder ---
                          - button:
                              width: 250
                              height: 50
                              on_click:
                                then:
                                  - switch.toggle: living_light_switch
                                  - logger.log: "Toggled 3 via HA service"
                                  - if:
                                      condition:
                                        switch.is_off: living_light_switch
                                      then:
                                      else:
                              widgets:
                                - label:
                                    text: "Living Room"
                    # --- Counter Section ---
                    - obj:
                        width: 360
                        height: 240
                        y: -10
                        align: BOTTOM_MID
                        widgets:
                          # Counter Display Label
                          - label:
                              width: 330
                              align: TOP_MID
                              x: 15
                              y: 15
                              text: !lambda 'return "Counter: " + std::to_string(id(counter));'
                          # Counter Buttons Container
                          - obj:
                              width: 330
                              height: 80
                              align: BOTTOM_MID
                              y: -20
                              layout:
                                type: flex
                                flex_flow: ROW
                                pad_column: 10
                              bg_color: 0x222222
                              widgets:
                                # Increment Button
                                - button:
                                    styles: button_style
                                    width: 70
                                    height: 60
                                    on_press:
                                      then:
                                        - lambda: |-
                                            id(counter)++;
                                            lv_label_set_text(id(counter_display), ("Counter: " + std::to_string(id(counter))).c_str());
                                    widgets:
                                      - label:
                                          text: "+"
                                # Reset Button
                                - button:
                                    width: 90
                                    height: 60
                                    on_press:
                                      then:
                                        - lambda: |-
                                            id(counter) = 0;
                                    widgets:
                                      - label:
                                          text: "Reset"
                                # Decrement Button
                                - button:
                                    width: 70
                                    height: 60
                                    on_press:
                                      then:
                                        - lambda: |-
                                            id(counter)--;
                                    widgets:
                                      - label:
                                          text: "-"
    - id: second_page
      widgets:
        - obj:
            width: 800
            height: 480
            widgets:
              - label:
                  text: "Settings"
                  align: TOP_MID
              - slider:
                  align: RIGHT_MID
                  x: -67
                  #y: 50
                  width: 30
                  height: 220
                  pad_all: 8
                  min_value: 1
                  max_value: 10
                  value: 8
                  on_change:
                    - light.turn_on:
                        brightness: !lambda |-
                          return x / 10.0;
              - label:
                  text: "Backlight"
                  styles: button_label_style2
                  align: RIGHT_MID
                  x: -50
                  y: -175
              - label:
                  text: "Max"
                  align: RIGHT_MID
                  x: -73
                  y: -130
              - label:
                  text: "Off"
                  align: RIGHT_MID
                  x: -73
                  y: 115
audio_dac:
  - platform: es8311
    bits_per_sample: 16bit
    sample_rate: 16000
    use_microphone: True
i2s_audio:
  - id: i2s_output
    i2s_lrclk_pin: GPIO10
    i2s_bclk_pin: GPIO12
    i2s_mclk_pin: GPIO13
speaker:
  - platform: i2s_audio
    i2s_audio_id: i2s_output
    i2s_dout_pin: GPIO9
    dac_type: external
    sample_rate: 16000
    channel: stereo
    audio_dac: es8311_dac
  - platform: mixer
    output_speaker: p4_speaker
    source_speakers:
      - id: announcement_spk_mixer_input
      - id: media_spk_mixer_input
  - platform: resampler
    output_speaker: media_spk_mixer_input
    output_speaker: announcement_spk_mixer_input
media_player:
  - platform: speaker
    name: "Speaker Media Player"
    media_pipeline:
        speaker: media_spk_resampling_input
        num_channels: 2
    announcement_pipeline:
        speaker: announcement_spk_resampling_input
        num_channels: 1
microphone:
    i2s_din_pin: GPIO11
    sample_rate: 16000
    adc_type: external
#audio_adc:
#  - platform: es8311
#    id: es8311_adc
#    bits_per_sample: 16bit
#    sample_rate: 16000
No DSI or RGB controllers support hardware rotation (since the driver chip does not host the display buffer.)
Clyde,
Thank you for the input. Do you have any insights on Camera Serial Interface (CSI) implementation?
Kat
No, sorry, have not looked at that at all. There is discussion on Discord in the P4 thread.
hi, im reposting the link i got for my device from the seller at aliexpress:
http://pan.jczn1688.com/1/HMI%20display
and as i mentioned on the other thread, on the link the zip package for the JC8012P4A1C was updated last month and it now contains an example for SW rotation under \1-Demo\arduino-examples\Arduino_lvgl_sw_rotation
if that helps
Hey! Thanks for your example code. I figured some parts out on my own, but this helped me immensely in getting my “hello world” dashboard running. I’m still trying to figure out the best way to do layout, but for now I’ve settled on using “flex” for the left and right container. That way I can add more components as I go without having to think about their exact positioning.
For my particular screen I had to turn off mirror_x since with it enabled my touchscreen was indeed mirrored.
Over the coming weeks I’ll try to clean up my dashboard code and share it. Right now it contains too many commented out parts from your code that I won’t be using for my particular use case.
Thanks again and hope to hear if you came up with any improvements on your end
Thanks for all the work on this. I made a version with just the hardware setup included.
I had to swap just the X access on the touch screen to get it working right. My Wi-Fi is not working but this may be because the C6 on my board doesn’t have an antenna. I’m getting one.
I also can’t get logging over the USB-C serial port working. All I get is this.
[13:18:09]ESP-ROM:esp32p4-eco2-20240710
[13:18:11]BESP-ROM:esp32p4-eco2-20240710
[13:18:11]Build:Jul 10 2024
[13:18:11]rst:0x1 (POWERON),boot:0x30f (SPI_FAST_FLASH_BOOT)
[13:18:11]SPI mode:DIO, clock div:1
[13:18:11]load:0x4ff33ce0,len:0x15f4
[13:18:11]load:0x4ff2abd0,len:0xcf0
[13:18:11]load:0x4ff2cbd0,len:0x3324
[13:18:11]entry 0x4ff2abd0
Thx for these configuration, it helped me a lot …
Thanks for the codes posted. I am able to get the display/touchscreen working plus some part of home assistant functionality. I am able to read HA entities status but not able to turn any HA entities switches on or off.
Probably because you didn’t give the device permission in HA as per the docs
Hi Clyde, you were absolutely right, I did not set the device integration configuration correctly. It now works perfectly. Thank you so much for your help.
Hi, Anyone knows what is SW1 push button switch connected to? I can’t seem to locate on the schematics.
SW1 is connected to the power IC IP5306 KEY pin
I got this error when I compile a previously error free, something is broken ``NOTICE: Dependency “espressif/esp_hosted (2.6.1)” version changed, solving dependencies.
…-- Configuring incomplete, errors occurred!
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:629 (message):
WARNING: Component “espressif/esp_hosted” not found
ERROR: Version solving failed:
  - no versions of espressif/esp_hosted match 2.6.1
  - project depends on espressif/esp_hosted (2.6.1)
Result: Because project depends on espressif/esp_hosted (2.6.1) which
doesn’t match any versions, version solving failed.
Call Stack (most recent call first):
/data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:740 (idf_build_process)
CMakeLists.txt:3 (project)
========================== [FAILED] Took 3.31 seconds ==========================```
This issue has been fixed in the latest version Esphome. After updating, click the “Clean All” button to update all libraries.
In the esphome version 2025.12.0, an error occurred during the build process. What did I do wrong?
Compiling .pioenvs/jc8012p4a1c/managed_components/espressif__esp_hosted/host/drivers/serial/serial_drv.c.o
Compiling .pioenvs/jc8012p4a1c/managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_core.c.o
Compiling .pioenvs/jc8012p4a1c/managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_req.c.o
Compiling .pioenvs/jc8012p4a1c/managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_rsp.c.o
Compiling .pioenvs/jc8012p4a1c/managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_evt.c.o
managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_req.c: In function 'compose_rpc_req':
managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_req.c:371:60: error: 'wifi_ap_config_t' has no member named 'gtk_rekey_interval'
  371 |                         p_c_ap->gtk_rekey_interval = p_a_ap->gtk_rekey_interval;
*** [.pioenvs/jc8012p4a1c/managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_req.c.o] Error 1
managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_rsp.c: In function 'rpc_parse_rsp':
managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_rsp.c:294:31: error: 'wifi_ap_config_t' has no member named 'gtk_rekey_interval'
  294 |                         p_a_ap->gtk_rekey_interval = p_c_ap->gtk_rekey_interval;
*** [.pioenvs/jc8012p4a1c/managed_components/espressif__esp_hosted/host/drivers/rpc/core/rpc_rsp.c.o] Error 1
========================= [FAILED] Took 70.76 seconds =========================
I not sure I built this morning with 2025.12.0 and it worked OK.
Try building this one. It works well.
Also run a esphome clean-all first
Thanks, I successfully built it in the esphome-dev version. It seems there’s an issue somewhere in my official esphome release.
Hello, I also used your code model but I have a small problem. I can’t get it to work in landscape.
