In case anyone stumble on a similar problem…
I thought I might share my solution.
Step 1
It seems that the problem with my original sensor has something to do with the 255-char limitation on a RESTful sensor’s state. Even though my template’s final result is either true
or false
, it seems that passing the entire value_json
for processing inthe state wasn’t working.
As a workaround, I used the sensor’s attributes (similar to the official example) to “dump” the JSON response I needed.
- platform: rest
# Dummy state; using the attributes which can hold >255 chars
value_template: OK
json_attributes_path: ...
json_attributes:
Step 2
Now came a tough part - how to simulate the for
loop I had in my template? That is, how to filter the JSON response, which includes an array of sessions, to find the only relevant one that contains NowPlayingItem
This was solved using some JSONPath magic, with the help of online exp tutorial, dummy data and tester. value_json
is filtered to give only that item which has a property key NowPlayingItem
json_attributes_path: "$[?(@.NowPlayingItem)]"
json_attributes:
- Id
- PlayState
- NowPlayingItem
Step 3
Now that I had the REST sensor, I used a template binary sensor to create the actual boolean value (and extract other useful info from the session object).
Final result:
- platform: rest
resource_template: "{{ states('input_text.jellyfin_url') }}/Sessions"
headers:
X-MediaBrowser-Token: !secret jellyfin_apikey
# Dummy state; actually using the attributes which can hold >255 chars
value_template: OK
json_attributes:
- Id
- PlayState
- NowPlayingItem
template:
- binary_sensor:
- name: Jellyfin playing
device_class: running
state: "{{ iif(state_attr('sensor.jellyfin_playing', 'Id') != None, 'on', 'off') }}"
attributes:
session_id: "{{ state_attr('sensor.jellyfin_playing', 'Id') }}"
is_paused: "{{ state_attr('sensor.jellyfin_playing', 'PlayState')['IsPaused'] }}"
name: "{{ state_attr('sensor.jellyfin_playing', 'NowPlayingItem')['Name'] }}"
rating: "{{ state_attr('sensor.jellyfin_playing', 'NowPlayingItem')['OfficialRating'] }}"
Multiple active sessions?
This does NOT address the case where there is more than one active playing session. In that case, the JSONPath $[?(@.NowPlayingItem)]
will return an array of matches, but the json_attributes
will populate only from the last match, I believe. If anyone has any ideas on how to solve THAT problem - lemme know!
