It is happy that I found this integration after few years.
But I found it cannot be updated on schedule, and it cannot be added into the energy dashboard, so I have made some changes.
Update it with proper unit_of_measurement, state_class and device_class, so that they can be added into Energy Dashboard
By pure coincidence I found this discussion on the same day you revived it (after 2 years!).
I tried installing your fork of the integration but unfortunately I was unable to configure it through the UI.
Looking into this I noticed that you had included the address of mvandersteen’s original git in your install instructions. git clone https://github.com/mvandersteen/ha-jemenaoutlook.git
I’ve also just come across this today, I couldn’t get it to install via hacs but the git clone (with correct address) method worked for me via the UI. Just have to figure out which sensor to add to the energy dashboard now.
It looks like the Energy Dashboard requires a total kWh reading from the meter. i.e. the total consumption since the meter was installed.
The closest thing I can find from the Jemena integration is the current month’s consumption. Using this will give a large negative reading at the start of each month.
Over the past two days I’ve been having lots of trouble connecting to the portal. I also see that the portal will be replaced in March next year… https://www.jemena.com.au/myportal
For this reason I’ll probably not put too much effort into this for now and just use the existing entities to get an idea of power usage.
