JetAir or Jet-Air Airconditioners
Hi All
I just had Jet-Air Aircons installed and I have a problem exposing it to HA. I added it to the Jet-Air App (Tuya does not seem to detect them) I have linked it to Google Home, but in Google Home I can only switch them on/off and set the fan speed :frowning:
Ideally it would be great to use the HA Climate Control, but I don’t seem to find the relevant xxxx.json file for Jet-Air. My only other option for now is to use the SmartIR integration, but it’s quite limited and cumbersome to setup each remote funtion.
Can anyone assist in either with a xxxx.json file or an app that fully integrates with Google Home?
Thank you kindly
I figured it out by using the Gree App. HA has a Gree Integration. Works great!
thanks for sharing your finding.
gree integration worked 1st time
Hi there, can you maybe confirm which Jet Air model airconditioner you have which you got working with the Gree Climate integration, is it the QPlus X?
I’m about to install new Jet Air aircons and was offered the QPlus X model rather than J-Smart. I know the QPlus X does not work with Tuya but only with the Jet Air app, but HA integration is essential for me, so I would like to confirm whether the QPlus X will be able to be integrated via Gree Climate.
My J-Smart and QPlus work perfectly
