So I am trying to keep code compact and I was looking to do the following.
I have a set of sensors with a set of names and corresponding values
Sensor.blueValue 100
Sensor.redvalue 345
Sensor.greenvalue 123
I have the following sensor:
Sensor.currentselectedcolor having value blue, red or green
Finally I have a sensor sensor.currentvalueforcolor which should hold the value of the sensor.Colorvalue corresponding to the current value of sensor.currentselectedcolor
So for example: if sensor.currentselectedcolor is red the sensor.currenvalueforcolor should be 345
I know this can be done through a chain on if then else in a template sensor but I am looking for a more compact solution (if it exists)
I can form the data source entity_id with the following
States.sensor.{{ states.sensor.currentselectedcolor.state}}value.state
But I cannot manage to have this generated literal evaluated once again and assigned to a template sensor sensor.currentvalueforcolor
So. Is there a way to do :
Template:
- sensor
State: >
{{ evaluation of(States.sensor.{{ states.sensor.currentselectedcolor.state}}value.state) }}
So by double evaluation I mean first evaluating the inner expression and then evaluating the resulting expression.
In this elegant way I could avoid n subsections of an if then else else endif replacing them with 4 rows
Hope I was clear
Tx for any suggestions
