I am trying to create an automation that will alert for open windows at a specific trigger.
If only one window is open, I want something like “please close window in area”, but if multiple windows are open, I would like “the following windows are open; please close all of them: areaandareaandarea”.
I have this so far:
{% set fenster = ['binary_sensor.unten_kueche_fenster_contact', 'binary_sensor.unten_bad_fenster_contact', 'binary_sensor.unten_wohnzimmer_fenster_contact' ] %}
{% for each in fenster %}
{% if is_state(each, "on") %}
{{ area_name(each) }}
{% endif %}
{% endfor %}
Currently, this displays Unten/Bad, because only that window is open. So I would like please close window in Bad/Unten. But if all windows were open, this would be Unten/Bad, Unten/Kueche, Unten/Wohnzimmer, so I would like the following windows are open; please close all of them: Unten/Bad, Unten/Kueche, Unten/Wohnzimmer.
Also, if no windows are open at all, I would like to switch the action all together. I would du this via automation condition, but I don’t know, what to put there. Same goes for differentiating between phrase 1 (only one open window) and phrase 2 (at least two open windows).
I guess I could do some search & replace on the area_name, as - in this case - all windows will be on the ground floor (“Unten”), so this information doesn’t have to be mentioned.
{% set open = fenster | select('is_state', 'on') | map('area_name') | list %}
{% if open | count == 1 %}
Please close window in {{ open | first }}
{% elif open | count > 1 %}
Please close windows in {{ open[:-1] | join(', ') }} and {{ open[-1] }}.
{% else %}
No windows are open
{% endif %}
This will build a string of “window x, window y, window z” for each open window.
After it is a template to check that the string isn’t empty, it will only proceed if at least one of the sensors was ‘on’
Using that over the provided list will throttle the template. You want to always avoid using the states object or the states.<domain> object when you can.
Secondly, OP wants area name, not entity name.
This is identical to your template, but with optimizations
