Jinja in Command Line Sensor: Count as value, list as attribute
I need to get all devices from my ZigBee coordinator in a certain state. I want
  • those devices as attribute for the command line sensor
  • the number of all devices as value vor the command line sensor
Update
Update to shorten things up: is there a smarter way to get the total number instead of passing almost the same command for a 2nd time (not very efficient hammering the API)?
I decided as quick and dirty approach to simply mixing “list” and “count” in one command:
Current result
  - platform: command_line
    name: Aqara-Devices Missing Status-Updates
    unique_id: xyz
    command_timeout: 60
    command: 'curl -s http://192.168.1.1/api/ABC/sensors | jq -r "{ "devices": [ .[] | select(.manufacturername==\"LUMI\") | select(.lastseen < \"$(date -u -d@$(($(date +%s)-360)) +%Y-%m-%dT%H:%M:%S)\")] | map(.name) | sort | unique, "total": [ .[] | select(.manufacturername==\"LUMI\") | select(.lastseen < \"$(date -u -d@$(($(date +%s)-360)) +%Y-%m-%dT%H:%M:%S)\")] | map(.name) | sort | unique | length }"'
    value_template: "{{ value_json.total }}"
    json_attributes:
      - devices
Old stuff below
Devices achieved with:
curl -s http://192.168.1.1/api/ABC/sensors | jq -r "[ .[] | select(.manufacturername==\"LUMI\") | select(.lastseen < \"$(date -u -d@$(($(date +%s)-366)) +%Y-%m-%dT%H:%M:%S)\")] | map(.name) | sort | unique | join(\", \") "
…which gives e. g.:
Type Name 1, Type Name 2, Type Name 3
Counting those is done with
curl -s http://192.168.1.1/api/ABC/sensors | jq -r "[ .[] | select(.manufacturername==\"LUMI\") | select(.lastseen < \"$(date -u -d@$(($(date +%s)-366)) +%Y-%m-%dT%H:%M:%S)\")] | map(.name) | sort | unique | length "
which gives 3 in this example.
How to get both?
  • count as value
  • list as attribute
I managed to get the command output as attribute using this:
    unique_id: xyz
    command_timeout: 60
    command: 'curl -s http://192.168.1.1/api/ABC/sensors | jq -r "{ "devices": [ .[] | select(.manufacturername==\"LUMI\") | select(.lastseen < \"$(date -u -d@$(($(date +%s)-360)) +%Y-%m-%dT%H:%M:%S)\")] | map(.name) | sort | unique }"'
    value_template: "{{ value_json.devices | length }}"
    json_attributes:
      - devices
command itself returns this:
  "devices": [
    "Type Name 1",
    "Type Name 2",
    "Type Name 3"
Unfortunately counting is not working (currently giving 0 as sensor value).
This is really freaking me out as I’m simply unable to access the elements of “devices” to do a simple count (or length) in the value_template.
