Hi!
Is this a bug in HA?
Try this in the template editor:
{{6 * 0.1|round(1)}}
It evaluates to 0.6000000000000001. Why not 0.6?
And without the round function:
{{6 * 0.1}}
BR/Nicklas
Hi!
{{6 * 0.1}}
BR/Nicklas
Order of operations. The |round filter evaluates first on 0.1
Try:
{{ (6 * 0.1) | round(1) }}
The other oddness you are seeing is probably due to the finite accuracy limitation of floating point math in binary computation.
Ahhh, thanks!
Great!
Do you also know why this does not work?
{{(states('sensor.out') * 0.1 + 1)|round(1)}}
Get: Unknown error rendering template
{{(states('sensor.out') |float * 0.1 + 1)|round(1)}}
You can also use | int
if the sensor contains an integer (as a string) and you are a RAM miser
All states are stored as strings and need to be converted if performing math functions.
Ah, forgot that states(‘sensor.out’) is a string.
Thanks!
