This template
{{ '{:0.2f}'.format(0.1) }}
Should return 0.10, but returns 0.1.
Likewise
{{ '{:0.3f}'.format(0) }}
returns 0 rather than 0.000.
This is using HA 2021.11.0 via Docker. Do others get the same behaviour?
This template
Likewise
When used in HA as-is, the output strings are re-interpreted as numbers, and applied a default format.
Try with outputting some string along and you’ll see that the format is applied, e.g.
echo {{ '{:0.2f}'.format(0.1) }}
Bottom-line: Real issue, wrong culprit
PS: When I say real issue, it depends on the context. If it’s purely for display, yes it’s an issue. If you want to force the display format of a numeric state, that’s more a feature request.
PS2: Workaround: Add a unicode invisible character, e.g.
{{ '\U00002063{:0.2f}'.format(0.1) }}
