Jinja template OK, Logger message won't work?
I am receiving an update on light status from another system which I can see in logger as a first step to setting the entity state in HASS. I cannot workout why the template works OK, but the logger doesn’t - any ideas? TIA
The bare message is logged ok
service: system_log.write
  message: '{{ trigger.json }}'
  level: info
results
    message:
      Cortex_HAAPI:
        Light: Family Room Star
        State: |
          Family Room Star - On, Override : Temporary on + presence.
    level: info
Using the Dev Tools Template
{% set my_test_json = {
  "Cortex_HAAPI":{
   "Light": "Family Room Star",
   "State":  "|
          Family Room Star On, Override : Temporary on + presence."
{{ my_test_json.Cortex_HAAPI.Light  }}: {%
  if "On" in my_test_json.Cortex_HAAPI.State %}On  {% else %}Off {% endif -%}
gives the result:
Family Room Star: On
All Good :slight_smile:
However when I move this into an automation (first step to log the result in a likely usable format)
- alias: cortex light state
  description: "update light status on webhook message"
    - platform: webhook
      webhook_id: cortex-light-state
      #      timestamp:
      #      name: homeassistant.webhook.cortex-light-state
      message: "{{ trigger.Cortex_HAAPI.Light }}: {%
      if 'On' in trigger.Cortex_HAAPI.State %}On  {% else %}Off {% endif -%}"
      level: info
The logger reports
Error: Error rendering data template: UndefinedError: 'dict object' has no attribute 'Cortex_HAAPI'
What have I got wrong??
According to the documentation for a Webhook Trigger, if the received data is in JSON then the variable to access it is trigger.json.
Based on that information, use:
trigger.json.Cortex_HAAPI.Light
trigger.json.Cortex_HAAPI.State
Awesome thank you very much.
:smiley:
