Hi there,
I have a script working well
all_lights_off:
alias: 'Nobody home all off'
sequence:
- service: light.turn_off
data_template:
# Turns off all lights, except of ...
entity_id: >
{% set exclude_light = [
'light.shelly_kitchen',
'light.shelly_floor'
{%- for device in states.light|rejectattr('entity_id','in',exclude_light)|rejectattr('state','in','off')|rejectattr('state','in','unavailable') %}{%- if loop.first %}{%- else %}, {% endif %}{{device.entity_id }}{%- if loop.last %}{% endif %}{%- endfor %}
This script works, but throws an error if no light is on. As soon as one light is on (but not light.shelly_kitchen and not light.shelly_floor) there are no errors anymore.
The problem is the ‘for loop’ if its result ist empty. What can I do to prevent that?
Errors:
Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data['entity_id']
File "/usr/src/homeassistant/homeassistant/core.py", line 1276, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1295, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 204, in service_handler
await script.async_turn_on(variables=service.data, context=service.context)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 280, in async_turn_on
await self.script.async_run(kwargs.get(ATTR_VARIABLES), context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 831, in async_run
await run.async_run()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 555, in async_run
await self._async_run()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 572, in _async_run
await self._async_step(log_exceptions=not propagate_exceptions)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 153, in _async_step
self, f"_async_{cv.determine_script_action(self._action)}_step"
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 656, in _async_call_service_step
*self._prep_call_service_step(), blocking=True, context=self._context
File "/usr/src/homeassistant/homeassistant/core.py", line 1222, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 208, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 287, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 283, in _exec
v = func(v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: not a valid value for dictionary value @ data['entity_id']
Both errors pop up at the same time.
I appreciate any help
