You can use the Template Editor in Developer Tools to see how the output will look. Just paste the whole line and it will show the parsed result on the right-hand side.
So simple! Thank you. Now I understand how it works. The code errored in the Template Editor, but I have never used it. I will look into it. Appreciate the reply.
Oops! You were using backquotes (`) and I just copied/pasted without testing it in the Template Editor (as I recommended to you ). Try it this way (with single quotes ('):
