So according to the docs my system does meet all requirements.
My HA system is:
Home Assistant 2022.11.1 Supervisor 2022.10.2 Frontend-versie: 20221102.1 - latest
Still, with all those steps I can’t get rid of the message:
update OS-agent to 1.4.1
update HA to 2022.11.1
reinstall the systemd journal service
update / upgrade Debian Bullseye
rerun the supervised installer
reinstall Docker
multiple host restarts
Also, I’m very sure, that about a week a go I have been checking the system info and logs, and there was not any sign of being unsupported. I will directly see that, if it was there.
Something must have changed. Something, that is beyond all the installation docs.
Ah. Yea I think something does need an update. The supervised adr mentions this:
Systemd journal gateway is enabled and mapped into supervisor as /run/systemd-journal-gatewayd.sock
I was under the impression that the installer had been updated to handle that but perhaps not. I’ll do some digging. Also looks like the ADR didn’t list systemd-journal-gatewayd in the software list when it was updated to include that additional step 2 months ago.
The installer also lacks the installation of connectivity check, which is mandatory for ages. If I run the installer now, it just rewrites the config and connectivity check is gone and must be re added manually again.
I got the systemd journal issue after the update of supervisor-2022.10.2 before that i did not have the error with 2022.11
I installed systemd-journal-remote and started the service (also at boot)
After restart of the system still the error.
Than I installed the lasted homeassistant-supervised.deb, rebooted and error was away.
All I did was what I wrote above while following errors that were reported when doing so. I.e. I had messages that I need to update some packages in order for it to fully complete. It was easy to do if you read the results of the commands. I’m not at home, so I can’t post everything I had to do.
I made an issue. Let’s take this discussion there as the installer needs to either be updated or the guide does as it appears there’s something missing.
Please make another issue in that same repo. Seems that needs to be updated too.
Worked like a charm before update, 2022.11, even updated to 2022.11.1 still not working
But then again the Picture Elements stopped pushing aspect ratio a long time ago too, so now it CROPS instead of CONSTRAINT the image to FIT the aspect Ratio.
Would love both to be fixed, but at least the First one is a little more important
I cant even reinstall homeassistant-supervised.deb because it fails with os-agent dependency, but os-agent is installed already. I tried 1.2.0 1.3.1 and 1.4.1 versions and .deb installation fails with all of them.
Make sure you’re cleaning out the folder that you’re downloading the deb installer to - I found it was making .1 - .3 entries and I was blindly reinstalling the same old supervisor (1.1.0) instead of the most recent (1.3.1)
root@homeassistant:~# dpkg -i homeassistant-supervised.deb
(Reading database ... 294458 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] ModemManager service is enabled. This might cause issue when using serial devices.
Leaving 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Leaving 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Leaving 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Leaving 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.3.1) over (1.1.0) ...
Setting up homeassistant-supervised (1.3.1) ...
[info] Restarting NetworkManager
[info] Restarting docker service
PING checkonline.home-assistant.io (172.67.68.90) 56(84) bytes of data.
64 bytes from 172.67.68.90 (172.67.68.90): icmp_seq=1 ttl=54 time=26.2 ms
--- checkonline.home-assistant.io ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 26.219/26.219/26.219/0.000 ms
[info] Install supervisor startup scripts
[info] Install AppArmor scripts
[info] Start Home Assistant Supervised
[info] Installing the 'ha' cli
[info] Switching to cgroup v1
Generating grub configuration file ...
Found background image: /usr/share/images/desktop-base/desktop-grub.png
Found linux image: /boot/vmlinuz-5.10.0-13-amd64
Found initrd image: /boot/initrd.img-5.10.0-13-amd64
Found linux image: /boot/vmlinuz-5.10.0-12-amd64
Found initrd image: /boot/initrd.img-5.10.0-12-amd64
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
error: invalid volume.
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Adding boot menu entry for UEFI Firmware Settings ...
done
[info] Within a few minutes you will be able to reach Home Assistant at:
[info] http://homeassistant.local:8123 or using the IP address of your
[info] machine: http://172.24.0.250:8123
[warn] A reboot is required to apply changes to grub.
sudo dpkg -i homeassistant-supervised.deb
(Reading database ... 40505 files and directories currently installed.)
[warn]
[warn]
Unpacking homeassistant-supervised (1.3.1) over (1.3.1) ...
dpkg: dependency problems prevent configuration of homeassistant-supervised:
homeassistant-supervised depends on os-agent.
dpkg: error processing package homeassistant-supervised (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
