Journal issues with supervised install after updating to 2022.11
gdbus introspect --system --dest io.hass.os --object-path /io/hass/os
node /io/hass/os {
  interface org.freedesktop.DBus.Introspectable {
    methods:
      Introspect(out s out);
    signals:
    properties:
  interface org.freedesktop.DBus.Properties {
    methods:
      Get(in  s interface,
          in  s property,
          out v value);
      GetAll(in  s interface,
             out a{sv} props);
      Set(in  s interface,
          in  s property,
          in  v value);
    signals:
      PropertiesChanged(s interface,
                        a{sv} changed_properties,
                        as invalidates_properties);
    properties:
  interface io.hass.os {
    methods:
    signals:
    properties:
      @org.freedesktop.DBus.Property.EmitsChangedSignal("invalidates")
      readonly s Version = '1.4.1';
      @org.freedesktop.DBus.Property.EmitsChangedSignal("true")
      readwrite b Diagnostics = false;
pi@homeassistant:~ $ sudo dpkg -i homeassistant-supervised.deb
(Reading database ... 40505 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] ModemManager service is enabled. This might cause issue when using serial devices.
Leaving 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Leaving 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Leaving 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Leaving 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.3.1) over (1.3.1) ...
dpkg: dependency problems prevent configuration of homeassistant-supervised:
 homeassistant-supervised depends on os-agent.
dpkg: error processing package homeassistant-supervised (--install):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
try
sudo dpkg --pending --configure
dpkg: error processing package homeassistant-supervised (ā€“configure):
I dont have hassio os, but can you install this os-agent package?
You have dependency problem. Maybe homeassistant-supervised is to new package for your dependencies. Maybe downgrading homeassistant-supervised will resolve this issue. Iā€™m not sure.
node /io/hass/os {
    methods:
    signals:
    properties:
    methods:
      Get(in  s interface,
          in  s property,
          out v value);
             out a{sv} props);
      Set(in  s interface,
          in  s property,
          in  v value);
    signals:
    properties:
    methods:
    signals:
    properties:
That command shows that the os-agent is installed.
I would try to check what version of os-agent you have. Here is my output.
nick@hass:~$ dpkg -s os-agent
Package: os-agent
Status: install ok installed
Priority: extra
Section: default
Installed-Size: 6524
Maintainer: Home Assistant <[email protected]>
Architecture: amd64
Version: 1.4.1
Depends: udisks2
Description: Home Assistant OS Agent
Homepage: https://www.home-assistant.io
EDIT, I typed this before your last message, but wouldnā€™t hurt to try.
I understand that its installed but ie. homeassistant-supervised v1 requires os-agent v1. If you install homeassistant-supervised v2 it will throw you a dependency problem because this v2 requires os-agent v2.
With respect to systemd-journal-gatewayd and unsupported installs, first step is install the package.
# apt-get install systemd-journal-remote -y
OK, so hereā€™s what the HA installer actually does and how it differs from the default Debian/Raspbian installation.
The HA installer creates the file /usr/lib/systemd/system/systemd-journal-gatewayd.socket. This has a different socket specified from the default, IE this is the key line:
ListenStream=/run/systemd-journal-gatewayd.sock
In my case on Debian/Raspbian, I donā€™t want the HA startup file in that location because itā€™s going to be overwritten by any OS upgrades to that package. The better way is to use the /etc directory for systemd.
# cp /usr/lib/systemd/system/systemd-journal-gatewayd.socket /etc/systemd/system
# vi /etc/systemd/system/systemd-journal-gatewayd.socket
Change the ListenStream line as follows and save/exit:
# systemctl daemon-reload
# systemctl enable systemd-journal-gatewayd.socket
# reboot
Now look in /run and you should see a socket called systemd-journal-gatewayd.sock
# ls -l /run
srw-rw-rw-  1 root     root        0 Nov  3 17:57 systemd-journal-gatewayd.sock
OK, so good news is now we have the socket and in the correct place for HA to look for it.
In my case the challenge is that the unsupported message has not gone away with that change. Any ideas as to why? Itā€™s world writable.
check
systemctl status systemd-journal-remote
Yes, for me too. The issue on Github leaded me to the problem. using wget I got a new package with .1 at the end homeassistant-supervised.deb.1, but the install command called homeassistant-supervised.deb, so an old image was installed.
Sad, I did overlooked thisā€¦
But, hey, full reinstall of the package as a solution to keep a system running is still weirdā€¦
This did the trick for me: error in Home Assistant is gone, and i am able to see Host logs within Home Assistant.
However, when running the below following command, i see status ā€œinactiveā€. Is everything now fine, or not? Iā€™m a bit confused.
pi@raspberrypi:~ $ systemctl status systemd-journal-remote
ā— systemd-journal-remote.service - Journal Remote Sink Service
     Loaded: loaded (/lib/systemd/system/systemd-journal-remote.service; indirect; vendor preset: disabled)
     Active: inactive (dead)
TriggeredBy: ā— systemd-journal-remote.socket
       Docs: man:systemd-journal-remote(8)
             man:journal-remote.conf(5)
Ooh. while reading the logs, i can see it is actually not working:
sudo systemctl start systemd-journal-remote
systemctl status systemd-journal-remote gives the following output:
     Active: failed (Result: exit-code) since Fri 2022-11-04 00:49:22 CET; 6s ago
    Process: 10666 ExecStart=/lib/systemd/systemd-journal-remote --listen-https=-3 --output=/var/log/journal/remote/ (code=exited, status=1/FAILURE)
   Main PID: 10666 (code=exited, status=1/FAILURE)
      Error: 13 (Permission denied)
Nov 04 00:49:22 raspberrypi systemd[1]: Started Journal Remote Sink Service.
Nov 04 00:49:22 raspberrypi systemd-journal-remote[10666]: Failed to read key from file '/etc/ssl/private/journal-remote.pem': Permission denied
Nov 04 00:49:22 raspberrypi systemd[1]: systemd-journal-remote.service: Main process exited, code=exited, status=1/FAILURE
Nov 04 00:49:22 raspberrypi systemd[1]: systemd-journal-remote.service: Failed with result 'exit-code'.
Nathan, I love you! :grin: I only looked at ā€žlatestā€œ in the wget but ignored the download directory. So happy now after hours of searching high and low.
Thanks for this, the error cleared for me. Same ā€œissueā€ as @pimw though, but I guess I can live with that.
And that is why one should better not just blindly doing copy-pastes when working from the shell but also read what the shell is reporting back:
[crosspost]
BAH, I reinstalled my supervisor using the link from above and now Iā€™ve lost my add-on options and many of my previously installed things!
How do I get them back?
I thought Iā€™d restore the backup but I donā€™t even have backup listed in the settings/system menus!!
Iā€™m seeing this in my ha su logs:
22-11-03 20:16:29 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
22-11-03 20:16:30 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
wget tells you what the downloaded file is named. If it is identical to a file in the same directory it adds .1 then .2 etc.
I know, I just overlooked it. Frustration and concentration are not the best friendsā€¦ :wink:
What is an ā€œadd-on optionā€
What installed things. How did you install them?
What exactly did you do? The installer doesnā€™t just install the supervisor, it does lots of shit, none of which remove anything as far as I can see.
I had to do the same, but the warning is still present - although Iā€™m not sure that the service has been configured properly, not sure what the configuration is supposed to be though
systemctl --state=running --type=service shows me:
 UNIT                        LOAD   ACTIVE SUB     DESCRIPTION
  containerd.service          loaded active running containerd container runtime
  cron.service                loaded active running Regular background program processing daemon
  dbus.service                loaded active running D-Bus System Message Bus
  docker.service              loaded active running Docker Application Container Engine
  [email protected]          loaded active running Getty on tty1
  haos-agent.service          loaded active running Home Assistant OS Agent
  hassio-supervisor.service   loaded active running Hass.io supervisor
  NetworkManager.service      loaded active running Network Manager
  polkit.service              loaded active running Authorization Manager
  rsyslog.service             loaded active running System Logging Service
  ssh.service                 loaded active running OpenBSD Secure Shell server
  systemd-journald.service    loaded active running Journal Service
  systemd-logind.service      loaded active running User Login Management
  systemd-resolved.service    loaded active running Network Name Resolution
  systemd-timesyncd.service   loaded active running Network Time Synchronization
  systemd-udevd.service       loaded active running Rule-based Manager for Device Events and Files
  udisks2.service             loaded active running Disk Manager
  unattended-upgrades.service loaded active running Unattended Upgrades Shutdown
  [email protected]           loaded active running User Manager for UID 1000
  wpa_supplicant.service      loaded active running WPA supplicant
