If you’re running HassOS this should be reported as a bug in supervisor. A HassOS system shouldn’t have these issues unless you’re mucking around the os. If you aren’t, it’s a bug.
Anyone else that reads this should treat it as a bug if they too are running HassOS.
The solutions in this thread should only be for a supervised installation.
Sorry, I have the same issue but I can’t find out, which 4 lines from which post you are referring to, to solve the log flood.
I believe I tried literally every solution from every post in this thread (my instalation is not unsupported anymore), but my log still gets flooded with
Nov 12 17:49:16 systemd-journal-gatewayd[328373]: microhttpd: Setting TCP_NODELAY option to ON state failed: Operation not supported
Nov 12 17:49:16 systemd-journal-gatewayd[328373]: microhttpd: Setting TCP_CORK option to OFF state failed: Operation not supported
Nov 12 17:49:16 systemd-journal-gatewayd[328373]: microhttpd: Failed to push the data from buffers to the network. Client may experience some delay (usually in range 200ms - 5 sec).
So here’s something interesting. I believe that that log spam (all the microhttpd stuff) is only generated when you actually look at the Host log with Home Assistant. If you don’t look at the Host log with Home Assistant and inspect /var/log/journal/xxxx/system.journal with journalctl (sudo journalctl --file /var/log/journal/xxx/system.journal), you don’t see these messages. Once you inspect the Host log through Home Assistant, you see these messages with journalctl.
I’m loosing my mind over this issue, as nothing seems to help resolving it. My logs are just growing, system constantly writing to disk (luckily I’m not using SD card, as it would have been burnt for sure)…
Does anyone have any info, is it even dealt with on a developer level? Or where can I report it?
There is an issue opened on GitHub (Supervised installer), but there are so many different informations and (obviously) also different variations of the same issue in the same topic, that I completely lost the track, what’s the issue, what’s the solution and if it’s even posted in the correct repo…
Thx for the tip, I changed the setting, will see how it works. But I’m afraid this will only limit the log file size and it’s not really a solution to the actual problem.
Besides, my log files are just growing (and system writes to the disk all the time) regardless if I open the Host logs or not - it’s not induced by viewing Host log, it just does it all the time…
