Continuing the discussion from Card-mod - Add css styles to any lovelace card:
using
- type: custom:config-template-card
entities:
- input_select.theme
variables:
darkmode: states['input_select.theme'].state.includes(['ight','Dark','Matrix'])
card:
type: custom:auto-entities
show_empty: false
filter:
include:
- domain: person
not:
state: home
card:
type: map
hours_to_show: 48
dark_mode: ${darkmode}
card_mod:
style: |
ha-card {
box-shadow: none;
my goal is to set the maps to dark mode. This works fine if I only use 1 search string:
darkmode: states['input_select.theme'].state.includes('Dark')
so I know the template and the variable are seen correctly. However, all my includes
template versions in my config use either this method, or use it at the beginning:
if (['open', 'on'].includes(states[child_entity].state))
ofc I also tried
darkmode: ['ight','Dark','Matrix'].includes(states['input_select.theme'].state)
but that too errors. also tried quoting the full template or enclosing it in ().
even tried the regex style .state.includes('(ight|Dark|Matrix)')
which works in the jinja templates.
managed to do it verbosely:
variables:
theme: states['input_select.theme'].state
darkmode: >
states['input_select.theme'].state.includes('ight') ||
states['input_select.theme'].state.includes('Dark') ||
states['input_select.theme'].state.includes('Matrix')
As you can see I also defined variable theme, but I can not call that in the variable darkmode, so for now its useless
Could anyone please help me format the template correctly? thanks!
