ddragoev
(ddragoev)
March 19, 2021, 2:06pm
1
I have the following json data:
{"software_version": "NRZ-2020-133", "age":"9", "sensordatavalues":[{"value_type":"SDS_P1","value":"41.33"},{"value_type":"SDS_P2","value":"29.70"},{"value_type":"BME280_temperature","value":"0.65"},{"value_type":"BME280_pressure","value":"92408.47"},{"value_type":"BME280_humidity","value":"77.31"},{"value_type":"samples","value":"4993373"},{"value_type":"min_micro","value":"28"},{"value_type":"max_micro","value":"20231"},{"value_type":"interval","value":"145000"},{"value_type":"signal","value":"-80"}]}
I’m getting the data successfully with a http request but I’m not able to parse the values where value_type is SDS_P1 and SDS_P2.
This is the configuration I have currently:
- platform: rest
json_attributes:
- sensordatavalues
resource: http://192.168.8.20/data.json
value_template: "OK"
sensors:
pm10:
friendly_name: "PM 10"
value_template: '{{ states.sensor.home_air_quality.attributes["sensordatavalues"]["SDS_P1"] }}'
pm25:
friendly_name: "PM 2.5"
value_template: '{{ states.sensor.home_air_quality.attributes["sensordatavalues"]["SDS_P2"] }}'
(Taras)
March 19, 2021, 2:33pm
2
An easy way to determine the correct JSON path is to use JSONPathfinder .
Here’s your data in JSONPathfinder:
It indicates the correct path to the value of SDS_P1 is:
x.sensordatavalues[0].value
Translated into Home Assistant:
value_template: '{{ states.sensor.home_air_quality.attributes.sensordatavalues[0].value }}'
This will work provided that the data always reports SDS_P1 as the zeroth item in the sensordatavalues list. If that cannot be guaranteed then the template must be enhanced to search through all items in the list to find the one containing SDS_P1.
ddragoev
(ddragoev)
March 20, 2021, 1:31pm
3
Thanks Taras,
It’s working like this. However as the order can be changed do you know how can I search through the items in order to find the correct value?
123
(Taras)
March 20, 2021, 2:19pm
4
Like this:
value_template: '{{ (states.sensor.home_air_quality.attributes.sensordatavalues | selectattr('value_type', 'eq', 'SDS_P1') | list)[0].value }}'
I used the Template Editor to compose and test the template:
(Taras)
March 23, 2021, 1:46pm
5
Which of the two suggestions that I have provided has proven to work for you?
ddragoev
(ddragoev)
March 23, 2021, 2:29pm
6
Currently I’m using the first one and it’s working great.
(Taras)
March 23, 2021, 2:45pm
7
OK, glad to hear to hear it resolves the problem.
Please consider marking my first post with the Solution tag. It will automatically place a check-mark next to the topic’s title. It signals to other users that this topic has an accepted solution and helps people find answers to similar questions.
