JSON data without element
Hi, is there a way to get JSON data when there is no element? I need to get data from “values” - “43.98”…
   "status":"success",
   "isPartial":false,
   "data":{
      "resultType":"matrix",
      "result":[
            "metric":{
               "central_unit_label":"0",
               "device_model":"MHT03",
            "values":[
                  1698218620,
                  "43.98"
                  1698218920,
                  "43.98"
            "metric":{
               "device_model":"HT02",
            "values":[
                  1698218620,
                  "59.4"
                  1698218920,
                  "58.13"
            "metric":{
            "values":[
                  1698218620,
                  "54.16"
                  1698218920,
                  "54.16"
            "metric":{
            "values":[
                  1698218620,
                  "58.19"
                  1698218920,
                  "52.95"
You can use the list-index: the first “43.98” for instance can be reached by: data["result"][0]["values"][0][1].
This might not be fully correct but this will give an idea how it could be done :slight_smile:
Thank you @bouwew
This works fine:
{{value_json.data['result'][0]['values'][0][1]}}
You’re welcome!
