For some reason I’ve had this error popping up in my log.
16-11-12 18:22:38 aiohttp.client: Attempt to decode JSON with unexpected mimetype: text/plain; charset=“utf-8”
I thought at first it had to do with a custom component that I had initially composed in notepad++ and saved it after I had composed it which messes with the formatting sometimes, but even after unloading my custom components, it still is showing in my log. Its the only error I get in the log and it repeats itself and only started showing up in 0.32.1 Looking back through the terminal output I see where its thrown at, but it doesn’t reference any files or settings. Didn’t know if anybody had this before? Thanks
This was my problem - the error messages don’t really tell you. I would start by searching any YAML files that were recently changed. Did you copy and paste any examples from a website? That was my issue.
No I’ve poured through my config files, and checked formatting and encoding. I commented out all automations and scripting (as this is where most of my JSON is at) and can’t find it. It’s not really causing a problem, persay, more so my quest for perfection and an error free log.
