Json extraction from MQTT - I don't understand the error
trying to do a simple jason extraction but don’t understand why it does not work. Spend already quite some time testing different alternatives, but no luck.
Here is the error message I receive:
2023-02-15 09:11:00.491 INFO (MainThread) [homeassistant.components.mqtt.binary_sensor] No matching payload found for entity: Status Tür Gästetoilette with state topic: zigbee2mqtt/0x00124b0029117643. Payload: '{"battery":100,"battery_low":false,"contact":true,"linkquality":47,"tamper":false,"voltage":3100}', template output: 'True', with value template 'Template("{{value_json["contact"]}}")'
It is strange that it says “no matching output” but at the same time says template output: ‘True’.
This is my configuration.yaml:
    - name: "Status Tür Gästetoilette"
      unique_id: "myhome-eg-wc-door"
      state_topic: "zigbee2mqtt/0x00124b0029117643"
      value_template: '{{value_json["contact"]}}'
      payload_on: "true"
      payload_off: "false"
Its probably super simple. Can somebody help me?
Thanks!!!
Try:
value_template: '{{ value_json.contact }}'
Probably simpler to use the ha entity that zigbee2mqtt will have created.
Thank you for your help!
The solution was that I needed change the payload to:
      payload_on: True
      payload_off: False
