I am sure this is very simple but I can’t for the life of me figure it out.
I have a notification set up to send me a message via Pushover using the call notification node which works. I now want to set the priority for the message but I always end up with an API error so I assume my JSON is not formatted correctly.
The working notification is:
"message": "Door is open"
But if I change it to:
"message": "Door is open",
"priority": "1"
I get the API error. I can see from the HA Pushover page that should be a “sub” data field (sorry if that is not the correct terminology!):
- service: notify.entity_id
message: "This is the message"
title: "Title of message"
url: "https://www.home-assistant.io/"
sound: pianobar
priority: 0
But I can’t workout how to format the YAML to JSON for this.
