erikbjork
(Erik Björk)
December 31, 2019, 1:45pm
1
I’m trying to control switches etc in HA by sending MQTT messages to HA. I have this automation rule:
- alias: Control switches via MQTT
platform: mqtt
topic: homeassistant/to-ha/cmd
- service_template: "{{ trigger.payload_json['service'] }}"
data_template: >
{{ trigger.payload_json['data'] }}
The payload of my message is going to look like this:
"service": "light.turn_off",
"data": {
"entity_id": "group.kitchen_lights"
But this is not right. HA doesn’t like the configuration: expected a dictionary for dictionary value @ data['action'][0]['data_template']. Got None
How do I turn that JSON map to a dictionary?
Try:
platform: mqtt
- service_template: "{{ trigger.payload_json.service }}"
data_template:
entity_id: "{{ trigger.payload_json.data.entity_id }}"
erikbjork
(Erik Björk)
December 31, 2019, 4:31pm
4
Yes, that works. I’ve tried it. But I want to be able to use the same automation rule with different services and they use different attributes of data
E.g. set a value of an input_number
Oh, I see. Unfortunately a template can only result in a string, it can’t result in a dictionary.
erikbjork
(Erik Björk)
December 31, 2019, 5:58pm
6
OK! Thanks for making that clear! Then I’ll go with the approach of adding different automation rules for switches, dimmable lamps, inputs and so on.
