JSON MQTT payload access in automation
I set up a simple automation that listens to an MQTT topic and sends the messages ({{ trigger.payload }}) to my phone.
It works well, except I get the following error if the message is a serialised JSON object:
template value should be a string for dictionary @ data['message']
Is there some way to cast trigger.payload to a string, or to disable whatever is parsing the object in the first place? I tried {{ trigger.payload | string }}, but it didn’t help.
For now I’ve switched to serialising the messages as YAML.
This topic seems vaguely similar: Automation trigger on MQTT message with JSON payload not triggering - #2 by 123
Automation YAML:
alias: My alert
description: ""
  - platform: mqtt
    topic: mytopic
condition: []
  - device_id: deadbeef
    domain: mobile_app
    type: notify
    message: "{{ trigger.payload }}"
    title: Update
mode: single
Maybe this:
https://www.home-assistant.io/docs/configuration/templating/#tofrom-json
    domain: mobile_app
    type: notify
    message: "{{ trigger.payload | from_json }}"
    title: Update
Thank you! to_json is what I needed. The output ends up being enclosed in quotes, and quotes in the serialised string are escaped ("{\"MyKey\": \"MyValue\"}"), but at least it works.
