Hi, I just want to see if anyone knows how to integrate a JSON Output from a solis-inverter (Solar Panels) to Home Assistant, to be able to read it’s values. I have the following json output:
You do have problem with the json since there appear to be some trailing commas which makes the json invalid. For instance,
"model":"00B7",,"firmwareMain"
You have two consecutive commas here which is invalid json. Not sure how to clean this up, but maybe you can use a regular expression to parse the output since the word “power” only appear once in the json output.
My bad, I removed some information like MAC address and Serial Number, I might have skipped some commas in the process.
I did look at this https://www.home-assistant.io/integrations/rest/ before asking the question, but the only way I can get some specific data from the JSON output would be to use this line in cmd:
They seem to be a subdivision of energy. If I add the value_template as
‘{{ value_json.total }}’ or {{ value_json.today }}’
There is no data passed to home assistant. But if I write {{ value_json.energy }}’ I am getting the 2 values at the same time without proper formatting: something like
Also, if you haven’t figured it out, you dont need to restart Ha everytime you change the value_json, just go to server management and click on RELOAD REST ENTITIES AND NOTIFY SERVICES.
Wow thank you for both things, the value_template worked and yes I did reload HA each time I modify the configuration.yaml file. Way better to just reload rest entities and notify services.
