JSON String template issue
Having issues getting the value I need out of this MQTT string from a generator controller
test_json outputs value 1
value_json outputs error: expected token ‘end of print statement’, got ‘E47E69B734F’
{% set test_json = {"one":{"two":{"three":1}}} %}
{{ test_json.one.two.three }}
{% set value_json = {"1922E47E69B734F":{"P019":{"R040":1}}} %}
{{ value_json.1922E47E69B734F.P019.R040 }}
Seems to be an issue with a combo of letters and numbers?
I am unable to change the format of the json from the device
Any help would be greatly appreciated
Because the name of one of the dictionary’s keys starts with a number, use bracket notation instead of dot notation.
{{ value_json['1922E47E69B734F']['P019']['R040'] }}
FWIW, the same advice applies if have an entity_id whose object_id starts with a number (such as light.12xyz).
Thanks heaps!
