My endpoint receives multiple JSON packets. Each from different temp sensors. I can’t change the way in which the endpoint receives this data.
Each specific JSON packet looks like this:
"event": {
"eventId": "c5rs364aa6gu3disj5ng",
"targetName": "projects/c2utvmhgmd8000fkmo90/devices/bjeis9e7gpvg00cjoapg",
"eventType": "temperature",
"data": {
"temperature": {
"value": 45.9,
"updateTime": "2021-10-26T08:50:24.504000Z",
"samples": [
"value": 45.9,
"sampleTime": "2021-10-26T08:50:24.504000Z"
"timestamp": "2021-10-26T08:50:24.504000Z"
"labels": {}
I can use in HA with success:
- name: "Water_Heater"
state: "{{ trigger.json.event.data.temperature['value'] }}"
unit_of_measurement: °C
However as each packet arrives I get sensor data from around 10 devices. I want to be able to filter based on the target name.
Can anybody please assist.
All help is appreciated.
Hellis81
(Hellis81)
2
I think you need to do something like:
state: >-
{% if trigger.json.event['TargetName'] == "projects/c2utvmhgmd8000fkmo90/devices/bjeis9e7gpvg00cjoapg" -%}
{%- endif %}
This means name has to be the above specified for it to set the value of this entity
dharvey24
(David)
3
thanks for looking at this much appreciated.
I have this in YAML:
state: >-
{% if trigger.json.event['targetName'] == "projects/c2utvmhgmd8000fkmo90/devices/bjeis9e7gpvg00cjoapg" -%}
{%- endif %}
And now I seem to be getting data from everything except the device in the if statement.
Hellis81
(Hellis81)
4
It’s not the history you’re looking at.
Before this change the same entity will keep the history of what it used to be.
But I just remembered that you probably need an else also.
{{ states(‘sensor.water_heater’) }}
Because otherwise it will probably return nothing/null/zero when it’s the wrong device and that is not what we want.
dharvey24
(David)
5
sorry bit of a noob when it comes to the syntax - something like this?
state: >-
{% else %}
{%- endif %}
dharvey24
(David)
6
For those following on at home - This works perfectly:
state: >-
{% else %}
{{ states('sensor.water_heater') }}
{%- endif %}
Thank you @Hellis81 !!
