So no arrays. Just items. But a Json-Timestamp as a attribute-key.
So I need to specify the actual timestamp under “json_attributes” and i don’t know how to do that dynamically. Even hardcoding the timestamp does not really work:
Please check the rest documentation
If you would have nester items then you would use the path to go to their parent and use the attributes to the details.
For what I can judge, you only need to set json_attributes to OriginResponseTimeChart, I cannot see a multi-level path in your data-example
No Problem. I now use a value-template as you suggested. This works. But it would be nice to have a possibility to parameterize the json-attributes somehow.
Yep… same feeling here, I have a couple of REST templates that I need to deconstruct as they provide multiple attribs and running them separately would bump into the limitations of calls/day
