I have the following configuration for a sensor-template in my configuration.yaml:
template:
- sensor:
- name: "SpeedTest CLI Ping"
unique_id: speedtest_cli_ping
icon: mdi:speedometer
# TIME_MILLISECONDS: Final = "ms"
unit_of_measurement: ms
state_class: measurement
state: "{{ (states('sensor.speedtest_cli_data') | from_json).ping | round(2) }}"
- name: "SpeedTest CLI Download"
unique_id: speedtest_cli_download
# DATA_RATE_MEGABITS_PER_SECOND: Final = "Mbit/s"
unit_of_measurement: Mbit/s
state: "{{ ((states('sensor.speedtest_cli_data') | from_json).download * 8 / 1000 / 1000) | round(2) }}"
- name: "SpeedTest CLI Upload"
unique_id: speedtest_cli_upload
state: "{{ ((states('sensor.speedtest_cli_data') | from_json).upload * 8 / 1000 / 1000) | round(2) }}"
- platform: command_line
name: "SpeedTest CLI Data"
unique_id: speedtest_cli_data
command: "/config/shell_commands/SpeedTest-TCP --output json"
scan_interval: 14400
command_timeout: 60
value_template: >-
"ping": value_json.ping,
"download": value_json.download,
"upload": value_json.upload
| to_json
And i have the following json:
{"client":{"ip":"123.123.123.123","lat":"123.123","lon":"123.123","isp":"SomeISP"},"servers_online":"10","server":{"name":"Frankfurt","sponsor":"Verizon.com","distance":"123.123","latency":"13","host":"somehost.net:8080"},"ping":"13","jitter":"14","download":"92146173.270521","upload":"32001713.157847","_":"all ok"}
If i look into my entities there are the entities but with “Not available”
In the log i can see following:
Logger: homeassistant.helpers.event
Source: helpers/template.py:569
First occurred: 16:57:37 (4 occurrences)
Last logged: 17:04:36
Error while processing template: Template<template=({{ (states('sensor.speedtest_cli_data') | from_json).ping | round(2) }}) renders=2>
Error while processing template: Template<template=({{ ((states('sensor.speedtest_cli_data') | from_json).download * 8 / 1000 / 1000) | round(2) }}) renders=2>
Error while processing template: Template<template=({{ ((states('sensor.speedtest_cli_data') | from_json).upload * 8 / 1000 / 1000) | round(2) }}) renders=2>
Error while processing template: Template<template=(mushroom-shape-icon { {% set vol_level = state_attr(config.entity, 'volume_level') | float %} --card-mod-icon: {% if state_attr(config.entity, 'is_volume_muted') == true %} mdi:volume-mute {% else %} {% if vol_level > 0.66 %} mdi:volume-high {% elif vol_level < 0.33 %} mdi:volume-low {% else %} mdi:volume-medium {% endif %} {% endif %}; }) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 567, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2305, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2160, in from_json
return json_loads(value)
File "/usr/src/homeassistant/homeassistant/util/json.py", line 43, in json_loads
return orjson.loads(__obj) # type:ignore[no-any-return]
orjson.JSONDecodeError: unexpected character: line 1 column 1 (char 0)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 693, in async_render_to_info
render_info._result = self.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 569, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: JSONDecodeError: unexpected character: line 1 column 1 (char 0)
The problem seems like:
What is wrong with my json?
