**Is your feature request related to a problem? Please describe.**
ts0601_cover….py needs a new quirk added to support this device properly.
Currently, it pairs with no entities attached.
**Describe the solution you'd like**
Be able to pair the device and control my curtains through HA.
<details>
<summary>Device signature</summary>
```yaml
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0051",
"in_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xef00"
"out_clusters": [
"0x000a",
"0x0019"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"manufacturer": "_TZE200_xu4a5rhj",
"model": "TS0601",
"class": "zigpy.device.Device"
</details>
<details>
<summary>Diagnostic information</summary>
```yaml
"data": {
"ieee": "**REDACTED**",
"nwk": 41871,
"model": "TS0601",
"name": "_TZE200_xu4a5rhj TS0601",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 4417,
"power_source": "Mains",
"lqi": 255,
"rssi": -56,
"last_seen": "2022-11-21T03:32:18",
"available": true,
"device_type": "Router",
"signature": {
"endpoints": {
"1": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xef00"
"out_clusters": [
"0x000a",
"0x0019"
"242": {
"in_clusters": [],
"out_clusters": [
"0x0021"
"active_coordinator": false,
"entities": [],
"neighbors": [],
"endpoint_names": [
"name": "SMART_PLUG"
"name": "unknown 97 device_type of 0xa1e0 profile id"
"user_given_name": null,
"device_reg_id": "7f6c4490a6fef24678202f5b7e3f2137",
"area_id": null,
"cluster_details": {
"1": {
"device_type": {
"name": "SMART_PLUG",
"id": 81
"profile_id": 260,
"in_clusters": {
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"unsupported_attributes": {}
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0xef00": {
"endpoint_attribute": null,
"attributes": {},
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0001": {
"attribute_name": "app_version",
"value": 70
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZE200_xu4a5rhj"
"0x0005": {
"attribute_name": "model",
"value": "TS0601"
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"242": {
"device_type": {
"name": "unknown",
"id": 97
"in_clusters": {},
"out_clusters": {
"0x0021": {
"endpoint_attribute": "green_power",
"attributes": {},
</details>
<details>
<summary>Additional logs</summary>
Paste any additional debug logs here.
Don't remove the extra line breaks outside the ``` marks.
</details>
**Additional context**
Add any other context or screenshots about the feature request here.
