Junk reminder automation problem
hi, I’m trying to do my first automation, for the disposal of garbage, but I can’t go on as these errors result, could someone kindly help me, thanks in advance.
the sensors were created with Garbage Collection
2022-11-23 23:35:03.115 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘dict object’ has no attribute ‘from_state’ when rendering ‘Attenzione: domani è giorno di ritiro frazione {{ trigger.from_state.attributes.friendly_name }}.’
2022-11-23 23:35:03.121 ERROR (MainThread) [homeassistant.components.automation.notifica_tts_ritiro_mastello] Notifica ritiro spazzatura: Error executing script. Error for call_service at pos 1: Error rendering data template: UndefinedError: ‘dict object’ has no attribute ‘from_state’
2022-11-23 23:35:03.137 ERROR (MainThread) [homeassistant.components.automation.notifica_tts_ritiro_mastello] Error while executing automation automation.notifica_tts_ritiro_mastello: Error rendering data template: UndefinedError: ‘dict object’ has no attribute ‘from_state’
this is the code of my automation:
alias: “Notifica ritiro spazzatura”
- platform: numeric_state
entity_id: sensor.plastica
value_template: “{{ state.attributes.days }}”
below: 1
entity_id: sensor.carta
below: 1
entity_id: sensor.umido
below: 1
entity_id: sensor.indifferenziata
below: 1
entity_id: sensor.vetro
below: 1
condition: []
- service: notify.mobile_app_iphone
message: “Attenzione: domani è giorno di ritiro frazione {{ trigger.from_state.attributes.friendly_name }}.”
How are you testing the automation?
If you’re testing it by executing the automation via the “Run” command then it will cause the errors you reported.
Reference: Testing your automation
even if I add a time in which the automation must start, it gives me the same errors
alias: Notifica ritiro spazzatura
  • platform: time
    at: 08:25:00
  • platform: numeric_state
    value_template: ‘{{ state.attributes.days }}’
    below: 1
    below: 1
    below: 1
    below: 1
    below: 1
    condition: []
  • service: notify.mobile_app_iphone
    message: ‘Attenzione: domani è giorno di ritiro frazione {{ trigger.from_state.attributes.friendly_name
It will produce the same error because a Time Trigger doesn’t provide trigger.from_state.
Reference: Time
You’re getting the error because you are testing the automation incorrectly.
To test it properly you must wait until one of the Numeric State Triggers gets triggered by the value of its days attribute decreasing below 1.
thank you taras for helping me, i will wait patiently
If you are interested, you can reduce the automation’s size like this:
alias: "Notifica ritiro spazzatura"
    entity_id:
      - sensor.plastica
      - sensor.carta
      - sensor.umido
      - sensor.indifferenziata
      - sensor.vetro
    attribute: "days"
    below: 1
condition: []
      message: "Attenzione: domani è giorno di ritiro frazione {{ trigger.to_state.name }}."
mode: queued
ok perfect thank you, but wanting to add the notification via alexa? what should i put in the code? I’m sorry if I’m taking advantage but I’m a beginner
and also enter a notification time
That’s easy. For example, this template displays the hour and minute.
{{ now().timestamp() | timestamp_custom('%H:%M') }}
It’s possible but it’s not straightforward. It requires a connection between your Home Assistant and Amazon’s Alexa services and there’s more than one way to do it. You can send a Text-To-Speech message to an Echo via:
  • Home Assistant Cloud (paid service provided by Nabu Casa)
  • Alexa Media Player custom integration
  • Direct connection if your Home Assistant is accessible via the internet
There are other ways as well but the one via Nabu Casa is probably the simplest (but it’s not free).
alexa I can make it talk via “service”, I integrated it into home assistant
Good! Then just use that service.
I created this code, can you tell me if there are errors, or if it can be improved:
    entity_id:
    • sensor.plastica
    • sensor.carta
    • sensor.umido
    • sensor.indifferenziata
    • sensor.vetro
      attribute: days
      below: 1
  • platform: time
    at: ‘20:30:00’
    condition: []
    title: Domotica
    message: ‘Attenzione: domani è giorno di ritiro frazione {{ trigger.to_state.name
  • service: notify.alexa
    target: media_player.alexa
    type: tts
    message: Attenzione: domani è giorno di ritiro frazione {{ trigger.to_state.name }}.
    mode: queued
It will fail to report trigger.to_state.name when it triggers at 20:30 for the reason I explained in my previous post. A Time Trigger only provides trigger.platform and trigger.now.
NOTE
Please format the YAML you post. Unformatted YAML is difficult to read.
Select the YAML and click the </> icon in the forum’s editing menu. For more information, refer to guideline 11 in the FAQ.
and how do I get the notification at a set time?
What do you want the notification to report at 20:30?
the notification both from alexa and on the phone
Based on your reply, you appear to have misunderstood my question.
The Time Trigger doesn’t produce trigger.to_state.name so it cannot use the same message as the one you have when the automation is triggered by its Numeric State Trigger.
The message it uses must reference different information. What is the information you want it to report? For example, do you want it to report the days value of each sensor or only the sensors that are below 1 or what?
I would like to have the notification both on the phone and on alexa of the ‘0’ which cyclically appears on the sensors I created with “Garbage Collection”, at a set time, for example 20:30sensori
This will send notifications only at 20:30 if any sensor’s days attribute is zero.
variables:
  sensors:
    - sensor.plastica
    - sensor.carta
    - sensor.umido
    - sensor.vetro
  zero_day: >
     {{ expand(sensors) | selectattr('attributes.days', 'eq' , 0)
       | map(attribute='name') | list }}
  - platform: time
    at: '20:30:00'
condition:
  - condition: template
    value_template: "{{ zero_day | count > 0 }}"
  - variables:
      names: "{{ zero_day | join(', ') }}"
      message: "Attenzione: domani è giorno di ritiro frazione {{ names }}."
  - service: notify.alexa
        type: tts
EDIT
Correction. Added missing data: to second notification.
