I don’t have read errors.
Enable uart debug to see exactly what you receive from junctek
uart:
tx_pin: ${tx_pin}
rx_pin: ${rx_pin}
baud_rate: 115200
debug:
direction: BOTH
dummy_receiver: false
after:
delimiter: "\n"
sequence:
- lambda: |-
UARTDebug::log_string(direction, bytes);
One of my friend had errors during battery charge (especially when charging also from AC). He changed ESP32 USB charger and solved.
@david_john
I tried to use shunt w/o display, no response sending R50 to same port.
I suppose you need to use display port
