Hi all,
I am looking to get a shunt KG140F to monitor my battery voltage, current, and SOC. It supports modbus over rs485. The problem is the manufacturer’s implementation of modbus. They have provided the documentation but i don’t know how to get HA to read register 50 which contains voltage, current, and SOC.
Someone has writen a code (not pyton) but i dont know how to convert to something HA can read.
Processing: juntek modbus.txt…
Any help appreciated.
Manufacturer’s manual
http://68.168.132.244/KG-F_EN_manual.pdf
Someone code
raslr6
(Raslr6)
August 8, 2022, 4:02pm
2
Hi, I’m also interested in the integration of this component, I have no idea of programming, I can’t help much, do you have any progress?
I also have a pzem through esphome and this works well since esphome has it integrated.
I don’t have a solution yet. I have also ordered a PZEM-017 which I intend to use with elfin ew11.
raslr6
(Raslr6)
September 21, 2022, 5:07pm
4
hi, i have an elfin ew11, do you have any progress with the junctek or pzem?
ronnyd23
(ron dekker)
December 20, 2022, 7:47am
5
I think i found something
mjanicek
(mjanicek)
December 26, 2022, 10:17pm
6
I also found this tutorial
Hello to all!
This is my first post and I’ very happy to join this community
I’m a noob, but I want to share my integration; it works after many tests and searches, but if there are some fix are welcome!
I’ve purchased this battery meter for my little photovoltaic system, 400A shunt version, but it too much for me
KG140F
It has a secondary serial port plug RJ10 (not rs485 modbus), I can read the values throught Tasmota and send them to Home Assistant.
This is…
Had any luck getting this working properly?
AORDU
(Aordu)
July 25, 2023, 5:27am
8
good morning
Someone has managed to communicate the KG-F100 with an EW11 over Wi-Fi to a home assistant. Could you explain the steps and configuration in EW11, and in HA.
Thank you.
Why not use the already working solution posted by @mjanicek . That is what I am using and works well.
AORDU
(Aordu)
July 25, 2023, 12:09pm
10
What card do I need, I have no experience with transmoting
AORDU
(Aordu)
November 3, 2023, 5:08pm
11
Hello .mjanicek. I have a KG-F 100 meter for the photovoltaic panels and battery of my motorhome and I want to connect it with Home Assistant. Could you give me more information about the material you needed (communication cards, wiring and programming in home assistant)?
Thank you very much in advance
Antonio Orduña
He used Wemos mini R1. Just follow the link @marcinek posted.
I used an esp32 but the process is the same.
Junteks shunt http://www.junteks.com/productinfo/226165.html
RS485 > LAN NB114-
The display must be disconnected!
configuration.yaml
# Example configuration.yaml entry
- platform: tcp
host: 192.168.0.200
port: 8887
timeout: 2
payload: ":R50=1,\r\n"
sensors:
voltage_meter_volts:
friendly_name: Battery Monitor - Volts
unique_id: voltage_meter_volts
value_template: "{{ float( states('sensor.VoltageMeter').split(',')[2] ) / 100.0 }}"
unit_of_measurement: "V"
voltage_meter_amps:
friendly_name: Battery Monitor - Amps
unique_id: voltage_meter_amps
value_template: "{{ float( states('sensor.VoltageMeter').split(',')[3] ) / 100.0 * ( 1.0 if ( states('sensor.VoltageMeter').split(',')[11] == '1' ) else -1.0 ) }}"
unit_of_measurement: "A"
voltage_meter_direction:
friendly_name: Battery Monitor - Direction
unique_id: voltage_meter_direction
value_template: "{{ 'Charging' if ( states('sensor.VoltageMeter').split(',')[11] == '1' ) else 'Discharging' }}"
voltage_meter_battery_remaining_capacity:
friendly_name: Battery Monitor - Remaining Capacity
unique_id: voltage_meter_remaining_capacity
value_template: "{{ float( states('sensor.VoltageMeter').split(',')[4] ) / 1000.0 }}"
unit_of_measurement: "Ah"
voltage_meter_battery_capacity:
friendly_name: Battery Monitor - Elapsed Ah
unique_id: voltage_meter_Ah
value_template: "{{ float( states('sensor.VoltageMeter').split(',')[5] ) / 1000.0 }}"
voltage_meter_battery_charged:
friendly_name: Battery Monitor - Charged
unique_id: voltage_meter_charged
value_template: "{{ float( states('sensor.VoltageMeter').split(',')[6] ) / 100000.0 }}"
unit_of_measurement: "kWh"
voltage_meter_battery_remaining_capacity_percentage:
friendly_name: Battery Monitor - Remaining Capacity Percentage
unique_id: voltage_meter_remaining_capacity_percentage
value_template: "{{ int( float( states('sensor.VoltageMeter').split(',')[4] ) / 2800.0 ) }}"
unit_of_measurement: "%"
voltage_meter_battery_remaining_capacity_time:
friendly_name: Battery Monitor - Remaining Capacity Time
unique_id: voltage_meter_remaining_capacity_time
value_template: "{{ float(states('sensor.voltage_meter_battery_remaining_capacity')|float(0)) / 10.0 / float(states('sensor.voltage_meter_amps')|float(0)) }}"
unit_of_measurement: "H"
voltage_meter_battery_power:
friendly_name: Battery Monitor - Power
unique_id: voltage_meter_power
value_template: "{{ float(states('sensor.voltage_meter_amps')|float(0)) * float(states('sensor.voltage_meter_volts')|float(0)) }}"
unit_of_measurement: "W"
voltage_meter_battery_temperature:
friendly_name: Battery Monitor - Temperature
unique_id: voltage_meter_temperature
value_template: "{{ float( states('sensor.VoltageMeter').split(',')[8] ) - 100.0 }}"
unit_of_measurement: "C"
voltage_meter_battery_power_in:
friendly_name: Battery Monitor - Power IN
unique_id: voltage_meter_power_in
unit_of_measurement: "kW"
device_class: power
value_template: >
{% set power = states('sensor.voltage_meter_amps')|float(0) * states('sensor.voltage_meter_volts')|float(0) / 1000 %}
{% if power >= 0 %}
{{ power }}
{% else %}
0
{% endif %}
availability_template: "{{ states('sensor.voltage_meter_amps')|is_number and states('sensor.voltage_meter_volts')|is_number }}"
voltage_meter_battery_power_out:
friendly_name: Battery Monitor - Power OUT
unique_id: voltage_meter_power_out
device_class: power
value_template: >
{% if power < 0 %}
{{ power|abs }}
{% else %}
0
{% endif %}
Integration - Riemann sum integral
- platform: integration
name: Battery Energy In
source: sensor.battery_power_in
method: left
name: Battery Energy Out
source: sensor.battery_power_out
method: left
@DeadmaroZ-TLOTL , this seems neater in my view. Can you share a picture of your connection between NB114 and Juntek shunt?
AORDU
(Aordu)
November 12, 2023, 9:27pm
17
Hello chukaonline. Do you have more information to make the connection with the ESP32, could you provide some photographs and video so that I can become familiar with this device and how to interconnect it to the KG-F through the RS 485 port…
Antonio Orduña
Mine is quite an untidy mess.
AORDU
(Aordu)
February 12, 2024, 2:58pm
21
Hola Chukaonline.
Podrias pasar mas fotos o un esquema a mano alzada entre el cableado del RS-485 LINK y la tarjeta EspHome?
Antentamente. Antonio
