I just finished setting this up and it’s working great, but I’m having an issue with my av receiver which is driving me crazy since months. It’s not an issue directly related to HA, but it’s impacting the functionality of an integration so I’d like to know if somebody of you had a similar experience and how you guys fixed it.
Basically what I’ve done is this:
Setup the Plex assistant and Plex integration
Setup IFTTT to configure the Google commands
When I try to say something like “Hey google, play this on plex”, TV turns on, the episode starts and then the AV receiver switch the source to TV instead of the Chromecast source (the HDMI where the Chromecast is plugged into). This is an extremely annoying issue since I have to use then the remote to switch the AV to the right source.
Does anybody have any idea how I can fix this? Once again, I know this isn’t HA related so if I have to delete this post, I will, but I really hope somebody can help out
First off, thanks for your answer!
So there’s an HA automation which is turning on the TV when the AV receiver is turned on (I disabled the automated turning on through HDMI CEC within the TV settings). The automation is based on a script which will turn the TV on via IR remote.
So, based on this configuration, neither the chromecast, nor the AV is turning the TV on themselves. Should I try to disable the automation and see what happens ?
I’m assuming that Plex Assistant intergration into HA or HACS is dead now? The github has been archived, and it cant be found when attempting to install through HACS.
Bascially my soul purpose for getting into HA was for my kids to be able to play movies and tv shows out of plex, using google to do it.
Is there something that replaces it?
I see where you’re going. The only thing I’m not sure about would be how would you configure the Google routines with a command like “Hey Google, play Games of Thrones on Plex” and then pass the command to HA changing the name of the TV series or movie. I see how to make it with IFTTT for example, but not with Google routines as I have no idea how to use text variable there.
