Just installed Home Assistant: shows Supervisor not Hass.io
Hi
I’ve just been trying to get HA setup the past two days and have run into a few difficulties. Some, my own fault and some things do not work. For example, I couldn’t get it to install on my Pi4 with a direct connection. After a few attempts, a new install using wifi worked.
It appears to be working on my browser now. I’ve not done much else but from the tutorials and help I’ve received, on the task bar, mine shows ‘Supervisor’ whereas all others seem to show Hass.io. Is this a problem? Have I installed the wrong version, although to me, following the installation guide, I followed the links.
Raspberry Pi 4 4gb
Fresh install on 32gb sd card
Wifi (although ethernet didnt work)
Hass os 3.12
Thanks you
most tutorials are outdated for that as of a couple versions ago when the names started being re-invented.
“supervisor” replaced “hassio” in the left side panel. (as far as I know since I don’t use hassio)
Yeah it did.
There is no “Hassio” now. It’s just called Home Assistant. Though it can still be found in the docs if you look hard enough.
Cheers guys. Explains things. It seems Configurator is now file manager too (or something similar to that). Had me confused again.
