Hello. Try to set up ESPHome on nodemcu as thermostat.
I configure 3 switches(restart, relay for boiler and relay for pump), 2 sensors (signal strengh and temp) and climate component.
In log i see all entitys, but in HA, i see just last entity from each category.
Here is my config:
switch:
- platform: restart
- platform: gpio
icon: mdi:fire
pin:
number: D6
mode: OUTPUT
inverted: true
- platform: gpio
icon: mdi:pump
pin:
number: D7
mode: OUTPUT
inverted: true
dallas:
- pin: D5
- platform: wifi_signal
update_interval: 60s
- platform: dallas
address: "0x37000004BF843728"
climate:
- platform: thermostat
sensor: boiler_temp
default_target_temperature_low: 24 °C
min_heating_off_time: 60s
min_heating_run_time: 60s
heat_deadband: 0.2
heat_overrun: 0.2
min_idle_time: 30s
visual:
min_temperature: 20 °C
max_temperature: 30 °C
heat_action:
- switch.turn_on: boiler_relay
idle_action:
- switch.turn_off: boiler_relay
that’s how i see it in HA:
what i do wrong?
