Just realized I had not set S2 keys in ZST39 LR setup
I’m running a Z-Wave network with about 36 devices currently and looking to add another 6 or so short term, probably another 10-20 longer term. Current project is adding Zooz ZSE42 (800) water sensors along with the Zooz Titan (700) water shutoff valve for water damage protection. In the course of adding the first few sensors, I realized the S2 security was not being set up and just now checked and realized when I set up the controller stick, Zooz ZST39 LR (800) about a year ago, I forgot to generate the S2 keys! I just did that, but am not sure what I should be doing as next steps. Couple of questions:
  1. The ZST39 LR is on firmware 1.20 according to HAOS Z-Wave integration. I have not updated the firmware since I first installed it and I see the warning about firmware based on SDK’s before 7.22.1 are buggy. I think that is firmware 1.5x, correct? Should I update it? Last time I looked it seemed like the recommendation was not to update unless experiencing issues.
  2. How can I identify which current devices are S2 compatible? Is it worth resetting devices, etc to enable S2?
  3. If a device is already included and setup, what do I need to do to enable S2 level security? I
I finally had a chance to keep adding some additional water sensors. Followed the SmartStart option and after Reinterview following the initial inclusion, its at S2 Authenticated status, everything in the green on the Z-Wave JS display of all nodes from the control panel. The ones I added previously have red locks and “no security” when I hover over them. So I guess I need to exclude, factory reset and then include them again via SS to get to S2 level?
And I have not updated the Controller firmware either, I will do that shortly before resetting all of the devices
Stick updated to 1.50 via Simplicity Studio with no issues
Now on to reset and reinclude via SmartStart to get to S2. Looks like I need to reset the Water Shutoff valve too.
I excluded and then included everything via SmartStart, including the Titan valve (QR code on the box), and everything is up and running.
Now to build or find some existing automation for alerting me when there is water detected, shutting off valve, etc
