Just received my ZWA-2, connected it to my HASS and got a firmware update, broken
So, I just unpack my ZWA-2, connect it to my HASS and it got recognized, I installed it following the wizard to setup a new Z-Wave network and everything went just fine. A few minutes later I got a firmware update to ZWA-2, I hit the update button, it started doing the firmware update and when it finished (I assume it finished installed since I wasn’t looking into the interface) it state the device was offline… I wait for a while but nothing happened… so I waited a bit more and then I check the logs of Zwave-js and I found the following message:
Blockquote
2025-09-18 04:02:53.626 DRIVER Controller is in bootloader, attempting to recover…
2025-09-18 04:02:54.629 DRIVER Failed to recover from bootloader. Please flash a new firmware to continue…
Error in driver ZWaveError: Failed to recover from bootloader. Please flash a new firmware to continue… (ZW0100)
at Driver.destroyWithMessage (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:3791:17)
at Immediate. (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1662:18) {
Shutting down
code: 100,
context: undefined,
transactionSource: undefined
[03:02:54] WARNING: Halt add-on
What should I do? How do I “Please flash a new firmware to continue…” ?
I would start here
Home Assistant Connect ZWA-2 - Quick Start Guide – Nabu Casa
And click the Submit a ticket button.
There’s a support article that address this problem specifically: https://support.nabucasa.com/hc/en-us/articles/30248635824413-My-Connect-ZWA-2-is-stuck-in-bootloader
Which advises you to run the recovery tool: https://support.nabucasa.com/hc/en-us/articles/30248838949405-Running-the-adapter-recovery-tool-on-Home-Assistant-Connect-ZWA-2
Yeah, I actually find it after and already fix it, I wasn’t able to recovery it with the tool, instead I needed to update the Firmware with the tool and that fix it…
(post deleted by author)
This is exactly what I had to do as well. The recovery itself didn’t work.
I have exactly the same issue, but when trying to run the recovery ‘Firmware download failed’. Where could I download the FW manually and then provide it as custom FW to load it into the ZWA-2?
It was working ‘fine’ after the very first connect, but then the FW upgrade bricked it.
I found the FW meanwhile: Found this one meanwhile: Release 1.1.0 · NabuCasa/zwave-firmware · GitHub
And it got even worse. Now I can not even connect anymore to the ZWA-2
