Just starting with HA. Experienced users preferred Addons
To all of the seasoned HA’s. If you new what you know now what would be your top 10 Addons?
Thanks for the help~
No takers…
I guess it is a very personal question? I have some stuff that might be useful to me but not to others. Like a lot of people recommend Grafana and a database plugin but I just don’t have a real use for them (And no time to set them up usefully anyways :stuck_out_tongue: ) You could have a look using the search function and searching for plugin, repository or something along those lines. I did that and found some great stuff!
Edit: Just had a look, I use:
DuckDNS, NodeRed, Configurator and NGINX. If you need any help with anything or want someone to help with kitting out your setup just hit me up :slightly_smiling_face:
Start small, you don’t need any addons. Get a couple of lights and a couple of sensors. Set them up, play with automations.
Look through the #projects forum, see what takes your fancy, get the components (including addons) together. Profit.
